Hi,Dev!The default UI font 1.0 is too small. E.g, I watch the YOUTUBE video tutorial, I can’t see the operation at all. I often need to change it myself.I recommend setting the default UI Resolution Scale to 1.2
I think, every system have different requirement. You can scale what you want and save setting so that when you comes latter to the software it picks that’s setting.
In common 1.0 scale is best for normal display event for hd. larger scales are looks boring i think.
As a meter of tutorial crater, it’s a special case they should keep that’s in mind how this video looks for viewer, you can request their to scale his/her software fonts, background color or some other suggestions.
