I’m trying to get a HIP compiler on Rocky 8 Linux working using these steps:
https://github.com/Bforartists/Bforartists/wiki/Install-HIP-Compiler-Linux#rocky-8
I installed the rocm-hip-sdk package successfully,
but now every time I try to update packages I get this message:
Error:
Problem 1: package rocm-hip-runtime-devel-5.3.2.50302-96.el8.x86_64 requires rocm-device-libs = 1.0.0.50302, but none of the providers can be installed
- cannot install both rocm-device-libs-5.2.3-1.el8.x86_64 and rocm-device-libs-1.0.0.50302-96.el8.x86_64
- cannot install both rocm-device-libs-1.0.0.50302-96.el8.x86_64 and rocm-device-libs-5.2.3-1.el8.x86_64
- cannot install the best update candidate for package rocm-hip-runtime-devel-5.3.2.50302-96.el8.x86_64
- cannot install the best update candidate for package rocm-device-libs-1.0.0.50302-96.el8.x86_64
Problem 2: package rocm-hip-runtime-5.3.2.50302-96.el8.x86_64 requires rocminfo = 1.0.0.50302, but none of the providers can be installed
- cannot install both rocminfo-5.2.0-1.el8.x86_64 and rocminfo-1.0.0.50302-96.el8.x86_64
- cannot install both rocminfo-1.0.0.50302-96.el8.x86_64 and rocminfo-5.2.0-1.el8.x86_64
- cannot install the best update candidate for package rocminfo-1.0.0.50302-96.el8.x86_64
- cannot install the best update candidate for package rocm-hip-runtime-5.3.2.50302-96.el8.x86_64
(try to add '--allowerasing' to command line to replace conflicting packages or '--skip-broken' to skip uninstallable packages or '--nobest' to use not only best candidate packages)
should I just pin the version of these two packages so that it won’t complain,
or is there a better way to get a HIP compiler on Rocky 8?
Thanks in advance,
Best regards,
Iyad
CC: @bsavery
