Hi I just tried the latest build and notice the hide overlay is missing from the Z pie menu, any chance of it returning?, I used that all the time.
See this: https://developer.blender.org/rB4022a16fbef81f5d4f2aaabd0d627d0c0f529561
But yes, even though those options have a direct hotkey now, it would be better to still have them in the pie menu. I donāt understand why it was removed, it kills the discoverability.
oh sweet, yeah I would preferred to have the pie menu way back, Iām heavily Dependant on them.
Also another issue with the keybinding is that AMD uses ALT+Z for itās Radeon Overlay also, another why I prefer Pie Menuās over keybindings.
Yes, this is an issue.
but shortcuts like Shift + Z is faster then pie-menu (at least for me)
itās back now with the option to have the previous pie menu or the 4 directions oneā¦i donāt think this is an issue because u can always modifiy the input or the script to make it work for you, the problem now is the x-ray and occluded option; i think one should stay in Alt+Z(occluded for edit mode) and the other in the pie menu(object mode) depending on their usiblity.
I just checked the new features and I love this choice.
at workflow level it is really very practical and immediate.
just the time to memorize the new type of use of the shortcurt and smooth row that is a beauty.
lol there is also āselect allā toggle hehehe!
I just turned it on ⦠and I realized that I missed it a lot ā¦
itās like Iām back to breathing ⦠very strange
yes yes yes ā¦
I wonāt miss that one⦠
at the end āalt + aā continues to work ⦠and Iāll remember to use it in case there is a lot of geometry and Iām going to deselect everything
Pie menu is weak point of workflow.
Especially, in shading modes, if it is needed to quit render via ZZ.
2.79 has wise solution
Z - wireframe (used 80% of times)
alt+Z - texture (8%)
Shift + Z - render (8%)
alt+shit+Z - material (4%)
other options are so much rare, that manual switch is pretty much suitable
So any kind of pie menu being just optional is nice choice.
Even the āextra shading pie menu itemsā checkbox doesnāt show the overlays option anymore. After all this time, is there a way to enable them on the Z pie menu? I know some people donāt use them, but Iām sure Iām not the only one who misses that feature. It was quite comfortable
What build of Blender are you using. Iām running the release version of 2.81 and I still have āToggle Overlaysā as an option on the z pie menu when āextra shading pie menu itemsā is on.
You are absolutely right. I donāt know why, but when I toggled it, it didnāt work. I even restarted Blender and nothing. But today it appeared. Not sure what happened but Iām glad it worked. I honestly thought they had removed it. Thanks for the help! Iām using 2.81 as well.
