Hello everyone! This thread would be dedicated for posting the weekly reports regarding my progress with this project. The proposal can be found here.
There is also a thread dedicated to feedback so please post your feedback there. It would really help me to improve this project.
Progress (until June 7th)
I worked on the project during the past couple of months (I had some free time ) and I have working implementations (more or less) of the two features I planned (see proposal). Note that it’s far from complete and has a lot of room for improvement. Especially the bevel tool which has a significant amount of work to be done from the side of UI.
Some discussing took place regarding the shortcut for closing curves. There are several options for this but none of them seem optimal. It would be helpful to hear any thoughts regarding the following options or any other suggestions for a shortcut. Please post them in the feedback forum):
Ctrl + click and drag from one end point to the other: The issue with this is that both deleting a point and making a cut on the curve are assigned to Ctrl+Click.
Click end point consecutively to close the loop: The issue with this is that selecting a point is also set to left click. So if someone wishes to select an end point after another they would either have to select something else or deselect before selecting which isn’t too bad but it’s not too intuitive.
There was also a bit of discussing on what could be done for the problem of functionality being re
In a previous discussion it was decided to implement the “bevel-like rounding of curve corners” tool as a geometry node. Furthermore, it would be named as Curve Fillet. Accordingly, I would be following this design task for the implementation.
Started working on the Curve Fillet node. Took some time to familiarize myself with the geometry nodes code and the C++ curve data structures. Currently working on the implementation.
Couldn’t get a lot done during the last week due to exams. Hoping to catch up this week.
Hi Dilith, my name is Peter Pienkowski; I’m the technical director from Elliott Animation in Toronto, Canada. We are also working on curve tool improvements, similar to yours. I’d like to offer you to take a look at what we are doing and approaching our development. You might be interested in the curve cutting tools we have.
Hi, Peter. Thanks a lot for the offer! I think it would be very helpful to have a look at what you’re working on. Could you direct me to where I need to look? Thanks!
Hi Dilith, could you please email me at [email protected] I would like to send you some footage of what we have, and if anything catches your interest, we can take it from there.
For the entirety of this week I worked on the Curve Fillet node. So far, the following is the design for the node (Pay no attention to the names of the fields; they’ll probably change ).
Adaptive: This enables the Angle field. In this mode, the number of points per segment is automatically adjusted based on the angle formed by the corner.
User Defined: This enables the Count field. In this mode, the user can specify the number of points per corner and all fillets would have the same count.
Radius Mode can be one of 2 values:
Float: This enables the Radius field. This can be used to define the radius of the fillet formed. The float shall be used by all corners.
Attribute: This enables the Radii field. This can be used to specify the distribution of radii for the entire curve.
Currently, I am using the curve’s built-in radius attribute to create a custom attribute (because I had an issue where built-in attributes weren’t detected) which defines the fillet radius for each vertex (see gif below). Ideally, an independent attribute should be definable using which the fillet radius can be defined for each vertex.
At the moment, the implementation only supports addition of a single vertex but it should be able to support the addition of multiple vertices before long.
There is a minor issue (mathematically) where the ends of the created arc aren’t parallel to the adjacent sides (See bottom right vertex in the gif above). However, this should be a fairly straight forward fix.
Plan for next week
Fix the incorrect arc issue and issue with inability to accept built-in attributes directly.
Work on creating fillets with higher resolution arcs.
Added support for circular arcs with multiple points: both adaptive and user defined (demonstrated in the gif using Poly splines because it’s easier to notice the difference).
As seen on the gif and in the image below, there can be situations where the specified radius cannot be fitted on to the given corner (note in the image that the radius is 1.380 while the height is only 1). The solution for this should be decided on. An option is to clamp the radius before it exceeds the maximum radius. Other suggestions are appreciated.
Added functionality for handling Auto and Align type handles (it may undergo further changes so I won’t post a video yet)
Searched on how NURBS curves can be filleted. The implementation isn’t trivial so currently it’s handled similar to Poly splines (which doesn’t give an exact circular arc). Eventually, it should support exact circular arcs, but with the time constraints, it may be looked into after the summer.
Tested Curve Pen and increased threshold for curve cut and vertex delete.
Plan for next week
Look into what changes need to be made to handle auto and align handles in the curve fillet tool.
Look into implementing additional features for the curve pen tool suggested by users. One such functionality I’ll be looking into would be to alter the curve by dragging the curve itself rather than using its control points.
Added functionality to close a spline by selecting two end points consecutively. Note that this would mean that, in order to select an end point while the other endpoint is selected, the user has to select a different point prior to selecting the endpoint. (See first gif)
Added functionality to alter a segment by clicking and dragging on the spline. (See first gif)
Added a checkbox to limit the radius in the curve fillet node in case overlapping is undesirable. (See second gif. In it, I increase the float radius. Notice that the radius is skewed towards the larger angle when the radius increases a lot. This is because the smaller angle would reach its limit faster than the larger angle. I’ll be looking into this the coming week.)
Added support for Poly and NURBS curves in Curve Pen. All functionality works similar to Bezier splines without the handle interactions. For making a cut on a NURBS spline, the poly-like lines need to be Ctrl clicked instead of the spline itself.
Fixed the issue with limit radius behavior. The shape of a segment after hitting its limit would be dependent on the ratio between the radii of the adjacent control points. The control point with the larger radius would get a larger portion of the segment.
Created an Experimental Build for the Curve Pen (found in Blender Builds - blender.org under branch name: soc-2021-curves). Note that it currently doesn’t build on Mac due to a bug in the master branch. I’ll update this post once its ready. For now, it should work fine for Windows and Linux.
Plan for the next week
Make changes according to code reviews on the patches.
Most of this week was spent on improving the curve fillet node code based on feedback on the revision. However, most of these changes shouldn’t affect the overall behavior of the tool.
Made vertex dissolve as the default behavior of delete vertex in curve pen.
Fixed bug where cuts cannot be made near control points due to cut distance not scaling with zoom level.
Other refactoring of the curve pen code.
It’s officially the end of the coding period but there are still some improvements left to be made, mainly to improve the code quality based on feedback on the revisions. So that’s the main plan for the next week and likely a few weeks following the next. I’ll post updates here or the feedback forum if anything new happens. Hopefully, I’ll be able get these . Additionally, I hope that people would get a chance to test out the builds (both available at Blender Builds - blender.org under the names: soc-2021-curves for the curve pen and soc-2021-curve-fillet for the curve fillet node) and provide feedback on what needs to be improved and whether there are any bugs/issues. I likely won’t be making any large changes in the upcoming weeks but I’ll definitely try to fix any bugs that may be encountered. Thanks for all the support so far!
Thank you! I think the curve fillet node might be merged fairly soon. I’m hoping within one or two weeks. The curve pen tool still has a fair bit to go. Not sure how long that’ll take since the focus was mostly on the curve fillet node so far (although there were a few improvements for the curve pen tool which I’ll summarize the next time I post). Hopefully, that too wouldn’t take too long .
@dilithjay
Dilith, thanks for your amazing job! I’m really thankful to you and I’m sure I’ll use your tools a lot in the future…
But now I only see chat about your GN fillet node (and I love that too) but your curve editing improvements are a god sent for practical use. Artists use chisels first and nodes (maybe) second
20 days later, do you have a better prediction on the curve editing merge?
Also have you (all of you) thought about filleting just being simply accessible by a rounding parameter of a curve endpoint? (I mean a NEW parameter)
I see some contradiction to use a radius parameter for it (which is thickness) instead of a separate roundness parameter. And if the new parameter is present, it should really be accessible from edit mode. Because why set up a node network just for specific end point rounding?
Again, chisels VS whole new systems.
I’m just thinking out loud here but I’m curious about your (and Hans’) opinion on this.
Yes, that’s right. We’ve been focusing on getting the fillet node ready (which it almost is. The revision was accepted so it should be merged any day now) but I’ll definitely work on the curve pen next. Won’t abandon it
However, since the code reviews haven’t exactly begun on the curve pen, I’m not certain as to how long it might take. Tools and geometry nodes are developed somewhat differently. I learned a fair bit of do’s and don’ts during the code review of the fillet node and there’s likely some of that for the tool as well so it may take some time but it should eventually get there
I myself have not thought about it. Not sure how that might work since filleting creates new vertices and the parameter wouldn’t make sense on the new vertices. Either way, this seems like a fairly major design choice so I’ll leave it to someone more experienced.
The built-in radius parameter was just used for testing TBH. Also, there were several significant changes to the fillet node inputs (the task summary in ⚙ D12115 Geometry Nodes: Add curve fillet node should summarize the node). The radius and count, both accept fields now. I’m not too familiar with fields so I’m probably not the best to talk about it but I believe in the long run, it would make the inputs more flexible.
I agree with you on the point that being able to fillet from the edit mode would be very useful. I believe the node was given priority because a design task was already in place for it when I had started the project. There’s been a bit of discussion for porting it to the edit mode as a tool (along with some other nodes I believe). Hopefully, that happens before long. I think @HooglyBoogly would be able to give a better idea if he’s available.
