Long story short, this is a limitation of multiple approximations:
The resolution of the signed distance field
Embedded deformation with self collisions
Nodal constraints
(Most of all) discrete collision detection
A flattened thin volumetric feature (like the monkey’s ear) is exactly where these approximations will have issues. Another example would be to take a thin flat volumetric sheet and drop it on a spike.
The manifold teapot can be improved/resolved with more substeps. The manifold monkey can be improved with more substeps, but not completely at the ear.
If you want to have colliding thin features, continuous collision detection is necessary.
Typically the lattice simulation avoids these types of artifacts. When thin surface geometry is embedded in a single tet, the thin surface won’t deform in a way where it can pass through itself (essentially it’s all treated as one element). That is not to say that reducing the resolution of the lattice is the best way to mitigate these artifacts, usually more substeps will do.
In any case, the lattice generated for the monkey mesh is a bit unfortunate:
The thin part of the ear falls almost exactly on the corner of the voxel, i.e it is split among multiple tets.
Tighter enveloping lattice generation (and more sophisticated volumetric meshing in general) is one of my suggestions for future work. In fact, it’s necessary for better soft body simulation.
Nice observation. It’s really nice to see that there are solutions to try. I’m thinking (artist brain) if this is a case where the “adaptive” concept would be a good try… Somehow do more lattice cells subdivisions right where the thinest parts are located… Again… this is an artist though, I don’t know if it is even possible…
There is already some adaptive subdivision going on. The voxels are subdivided up to a user specified amount (lattice resolution variable), but only if they contain surface faces. The problem here is that no matter how many times we subdivide, the ear will be at the corner of a voxel . Subdividing the tets and not the octree cells might yield better results.
The key to resolving these problems is a different embedding strategy, or perhaps allow the user to edit it directly.
Hello, I get this error when I try to build with MSVC2019:
C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC\14.22.27905\include\type_traits(1110,1): error C2338: You’ve instantiated std::aligned_storage<Len, Align> with an extended alignment (in other words, Align > alignof(max_align_t)). Before VS 2017 15.8, the member “type” would non-conformingly have an alignment of only alignof(max_align_t). VS 2017 15.8 was fixed to handle this correctly, but the fix inherently changes layout and breaks binary compatibility (only for uses of aligned_storage with extended alignments). Please define either (1) _ENABLE_EXTENDED_ALIGNED_STORAGE to acknowledge that you understand this message and that you actually want a type with an extended alignment, or (2) _DISABLE_EXTENDED_ALIGNED_STORAGE to silence this message and get the old non-conformant behavior. [F:\blender\soc-2020-soft-body\intern\softbody\bf_intern_admmpd.vcxproj]
C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC\14.22.27905\include\type_traits(1110,1): error C2338: You’ve instantiated std::aligned_storage<Len, Align> with an extended alignment (in other words, Align > alignof(max_align_t)). Before VS 2017 15.8, the member “type” would non-conformingly have an alignment of only alignof(max_align_t). VS 2017 15.8 was fixed to handle this correctly, but the fix inherently changes layout and breaks binary compatibility (only for uses of aligned_storage with extended alignments). Please define either (1) _ENABLE_EXTENDED_ALIGNED_STORAGE to acknowledge that you understand this message and that you actually want a type with an extended alignment, or (2) _DISABLE_EXTENDED_ALIGNED_STORAGE to silence this message and get the old non-conformant behavior. (ソース ファイルをコンパイルしています F:\blender\blender\extern\softbody\src\admmpd_bvh.cpp) [F:\blender\soc-2020-soft-body\extern\softbody\extern_admmpd.vcxproj]
I’m not sure if you really want to build it yourself. If your intention is to simply test the branch, here this is a build from 2020-08-25: https://blender.community/c/graphicall/spbbbc/
Edit:
New link, you search here for soc-2020 soft body branch:
I’ve noticed that loading time of first frame takes longer than other frames in large (and even baked) scene.
Is precomputation done at first frame instead of at hitting bake button?
Yes, there is precomputation being done on frame=1, but this is almost entirely volumetric mesh creation (creating the lattice/tetmesh), and not solver precomputation, which is actually quite fast.
Unfortunately I don’t think I will be doing GSOC again (though I did enjoy it). However, if somewhere else were to pick up where I left off (the interface) I would be more than happy to assist.
Hello, I am interested in 2021 GSOC about improving soft body simulation. I quickly read what you made last year. I understand you implement several new solvers for soft-body simulation. I would know what is reusable/doable or not. I haven’t sent apply yet, I would like some advice to make a coherent proposal. There is what I think I to propose :
-Making parameter depending on volume of the object and not the mesh to obtain same simulation when adding a subdivision
-Visualize parameter on vertex like mass, constraint, force
-Visualize intern spring created by bending option and being able to change them or redo this option.
-Improve pin system which isn’t enough user-friendly
-Add hyperelasticity or some cheating way to obtain this
Sure I’m happy to provide some feedback. The main limitation of the current branch is that the user interface needs improvement, specifically setting up simulations with multiple interacting meshes. This is because Blender doesn’t have the mesh type used by soft body solvers: tetrahedral meshes. I had to code in some automatic workaround that don’t always work so great - especially with multiple meshes. I highly recommend the proposal to focus on extending Blender to support tetmeshing. After that, improving the interface to the softbody solver (or new ones) becomes much easier. In any case, if you’re interested in improving the soft body solver you should reach out to Sebastian.
What parameters do you mean? Stiffnesses are independent of volume and mass is already computed from the volume.
The ADMM-PD solver already has hyperelasticity (neo-Hookean). Other models can be added trivially.
In the doc it is said, than mass parameter represent the mass value of vertices, I thought mass wasn’t computed from the volume. However, if you subdivide your model and keep same parameter, you will get a different behavior. It’s maybe all about the bending option. I don’t know exactly how it work and i haven’t find complete information about bending. (I’am talking about the soft-body on 2.92 blender version)
Thank for your feedback and agreed I have a coherent project. I will send draft proposal the sooner to get the mentor 's opinion.
Hello. I would like to try this blender branch but I have some errors compiling it. The master brunch compiled fine on my Ubuntu OS. I am sorry if this is a wrong place for asking. And if it is could you suggest where I should do that? I also want to add that the link to precompiled Windows libraries from here https://wiki.blender.org/wiki/User:Mattoverby/GSoC2020/mattoverby_final_report is dead. Have someone compiled the brunch recently?
This is as fine a place as any for reporting errors.
The branch hasn’t been merged from master since last summer, I suspect it’s related to that? Feel free to email me ([email protected]) with more details. I’ll try and take a closer look this weekend when I have a bit more time.
I’ve noticed that, it seems like the page for precompiled windows binary doesn’t exist anymore. Not sure where it went, but when if it gets hosted again I’ll update the link.
