I’m pretty sure many of you have noticed that when you add a limit rotation to a object, and give it the values, the object quickly snaps to that position you gave it to. BUT, there is something that doesn’t sync quite well, and that is the values of the location from the object.
Even tho the object moves to a limited location, you can still see in the location inside the item window that the values still change above the limited value instead of following the constraint.
This REALLY needs to be fixed.
Check “For Transform” option at the constraint options.
