Not sure if you are aware, Geometry Nodes in 3.0 just had a major change, including the Point Instance node you are talking about, this node is now replaced by Instance on Points
node, and it looks like this:
It does the “Whole Collection” behavior by default, you can enable the previous behavior by checking the Separate Children
on Collection Info
node and the Pick Instance
on the Instance on Points
node
