Just played with the Field proposal prototype build, and the new id attribute can be used like this in the prototype:
Amazing
Amazing
I must say i quite don’t understand the logic of this “ID” Attribute
it can be used to change instances randomly, indeed
but how to precisely choose which one, is not possible somehow? (afaik)
I was expecting that the ID would respect the order of the instances in the collection but it seem completely random so not sure how to use it at all
perhaps there’s something i’m missing
That’s because it’s random. The guarantee right now is only that elements with the same id will get the same object. Note that the id attribute exists in master already, it’s just not exposed.
Is there a way to make it not random? Like a certain index would only refer to a certain object in the collection, so that we can control the instance order?
No that is not possible right now. If you want to instance specific objects on specific points, you should splitup the points with a Point Separate node first currently.
This has been discussed in more detail here: ⚓ T84608 Specify per-object distribution ratio for moss use case
If there’s no way of users to know for sure that N id == X objects, then we are possibly missing the following opportunities
control instances spawn % rate by id
control instances spawn with color values
control instances spawn from the point scale attributes (important for realism)
control instances spawn with texture color values (very important for green walls and flower patterns ect)
All of the above is possible because i naively implemented “Instancing by index” with the nodegroup below (from 2.93) (with the help of the point separate)
But this was only possible because user know for sure that N id == X asset
Note that running multiple points separate in a row as suggested had severe impact on performance (this set up is 50% slower than random collection instancing) & also it add a lot of unnecessary complexity in the nodetree
So making this node not pick instance randomly, (by for example, if there’s 6 element in collection, 0,1,2,3,4,5 int value would correspond to the object order, perhaps everything above should repeat or be random) would add up a lot of opportunities, while making it pick random do not really add any advantages in this point instance node afaik?
I hope my feedback was useful
Bounding box display isn’t a solution either. When viewport shading is set to render preview all geometry is rendered fully even for opengl portion of the view as well. Here I have a couple objects with Viewport Display set to Bounds, but in render preview viewport you can see monkey outlines outside of render border.
It’s very hard to see because shading is set to a flat color that exactly matches that of your background, so it seems that it has been made difficult to see by design for some reason. So if you have a complex scene with thousands of hi-res objects scattered, then going into rendered mode will basically freeze up Blender. Not because Cycles can’t render it, but because your gpu is killing itself trying to show you billions of polygons, that you can’t really see anyway. The only workaround is to disable overlays before going into rendered mode, that seems to kill any opengl rendering. But it has its own drawbacks because: a) constantly switching overlays is annoying, b) if you forget to do that, things can end very badly and c) some overlays are important, like scene info in the top left corner.
Initial design goal for Geometry Nodes was object scattering/set dressing, but with broken viewport display it remains just a goal, sadly. I wonder how artists working on Sprite Fright deal with this issue, since they use GN extensively.
All that stopping me is being able to take the .matrix_world from a list of empty’s and @'ing it to a group of object’s .matrix_world over and over as deep as I want
Hello Everyone
where i can follow the vertices to point node task?
there’s a node that convert a mesh to point cloud that is in wip i believe
It would be very handy for every scattering workflow that scatter per vertices for example, right now all attributes are not transferred correctly (vertex groups/vcolors/Uv attr for example)
I’ll share here what I’ve managed to achieve with Geometry Nodes, maybe someone would find the info useful.
The last 4 videos are all done only with Geometry Nodes and I try to explain everything as clear as possible.
Shield Effect with Geometry Nodes
I’m also curious if there is a thread or something about Geometry Nodes progression?
I recently found this GN build that probably has all these WIP nodes, and I’m curious when we will see more nodes made available in the main builds.
In near future we got instance from nodes not objects/collections and its great,
but in this case I got questions how we can do loops?
something like this for every instance i need change seed in nodes.
Eh? It’s the seed of the randomization of that attribute. It makes little sense to randomize the randomizer which is responsible for randomizing an attribute of the array the output of which you want to use to randomize the seed.
why? if we have bricks wall for example. I create one brick randomized his parameters, then I instance him for all wall now we have all bricks with same parameters but if we change it with instance id we got more natural wall without created many inputs objects for instance.
and its not only for seed. we got many ways to randomize objects scale/rotate. and change them using instance id create much more interesting things
That Attribute randomize means that attribute on every element of the geometry input will receive random value. So if you have 100 points, then randomize their sizes and then use those instances to distribute brick meshes on them. That’s already possible.
its work only for size of instance. but if we got same more completed object not only cubes or spheres with gn damages edges or same more like damages etc?
Afaik this issue has not been tackled yet
it’s also a hard wall Ive been stuck on for a long time
Would Per-Vertex option in Point Distribute be relevant? Converting a mesh with UVs is complicated since a vertex can be associated with multiple faces (or face corners)?
It could work indeed
but imho the best would be this kind of node as some users already requested their need for a point per face center or point per edge center feature already (above in this thread *edit and right below)
Point per vertices might be the most common, seconded by point per faces
i must say i don’t see any use case for point per edges
*Note that this node would require automatic attribute transfer similar to what the point dist is doing ofc, because that’s the main problem with the current per vertex instancing workflow
About the attr problem, It’s true that face corner data can be tricky to convert, but isn’t it done already by the attr convert node?
