Data transfer already works on “attributes” in a legacy sense. Can you clarify?
I simply need to access the points position from another scatter objects!
but i can’t !
because blender only give me the position of each vertices of the applied instance geometry, i can’t work with this… there’s litterally billions of vertices… using them in an attr proximity node will just freeze blender to death
