Says who? Most people, even the ones making cartoons, go for realistic light behaviour. Especially beginners. I can know because I am one. (My statistics of what ‘most users’ want come from the same place where yours probably come from: the place where the sun don’t shine )
Linear light output from a render is way more confusing for most ‘beginners’ when doing 3d modeling.
Yes, that’s why the menu entry is there. For beginners to have sensible defaults. Or you could create your own startup file and make your defaults what you want them to be.
You’re seeing a problem where there isn’t any, you infantilize users that don’t want nor need your hand-holding.
And most importantly, you seem to fail to understand Blender is about choices. Filmic is, by far, the best default option for color management and Standard is the worst, actually, you’ve missed all the discussion about replacing Filmic with other tonemappers like ACES.
As been told by other users here, the Filmic render is totally correct, and even so, the greys prove it, I understand there are use cases where you want pure colors, but for that you have other color management options, and if you need stylized/cartoonish looks you’re not a beginner to start for, because you must deal with advanced stuff from day 1.
I recall 4 years ago being puzzled as you, “why white ain’t white? how do I get pure white?” until I understood I don’t need to. There isn’t anything like pure white in the world.
Blender is about choices and options, if Filmic isn’t for you, don’t use it, Blender gives you tons of choices regarding that and you can easily make those default. Don’t change Blender for others, change your Blender.
no, shaders and and nodes are advanced
the common man doesn’t need to learn shaders and nodes from day one
day one is to get used to things
and then learn advanced stuff
Most of these were most likely done with a color management: https://www.artstation.com/pablodp606
Your own artistic incompetence and lack of color management knowledge itself is not a proof that color management is a bad thing.
EDIT: Yep, he uses color management (as he should):
the professional, the studio
what about the new user?
why can’t you think about the new user for a second?
the one who doesn’t have a portfolio with hundreds of arts?
the little guy just starting?
the professional wont have a problem with filmic
leave the bubble for a second and look outside
exactly, they first need to notice that things look gray, be confused and then search and learn about it
they can’t just use it and then if needed learn about filmic
a problem that can only happen to a new user
and I wish this problem is avoided
because a professional wont have this problem
a professional knows about shading, color management, texturing, lightning
a new user doesn’t
when the new user learn about these things he will understand the benefits of filmic
but not on day one
The new user should never ever go to standard, the standard use case is VERY specific, in your anime image the character is burned out in the shoulders, and there is no way to avoid that, that burn out is also present in the eyes or the noise, if you want more contrast use the high contrast profile, but to get proper colors you should learn to use Filmic.
If you go outside and make a photo of a house with a white wall during a sunny day, and during a cloudy day, and then you put one besides the other the wall won’t be of the same color in the picture AT ALL, Standard is not a good way of working, you will get over saturated colors, under exposure and over exposure in lighting.
A new user is that, a new user, and as a new user that new user has to learn why has to use Filmic, not rely on Standard because when it configures a red in the material it looks red in the render… it should not… light is everything and interacts with the material, and management is there to allow us to properly work with screens that are so limited that can’t show nothing not even similar to real color, no matter if you work with cartoon or with a photorealistic scene.
New users should go to standard, and the learn about the benefits of filmic
these parts need to be birght, shoulders need to be sexy and visible
i will go outside and take a picture of an anime girl
realism isn’t everything, why can’t you think outside of this idea?
there are people who make opengl renders on Blender too
Cycles isn’t the only thing
If the new user doesn’t realize the problem, the moment he posts his first render online for ppl to admire/criticize, there will be someone who points out that it looks off…unless the whole community he is sharing it with is consisted of only “new users”…
I can’t believe this thread exists. OP has been sarcastic, has been engaging in bad faith arguments, made memes about the people who disagree with them, and somehow no-one has said anything about it?
Disrespecting people who disagree with you on ‘what most people need’ is not only incredibly rude but counterproductive. If someone wants to find out what the general public wants, then the answer is not arguing here, but researching further and finding evidence that proves the change would be beneficial.
Please let’s argue in good faith. We shouldn’t engage with conversations otherwise.
You seem to be the only one who wants standard as default, when everyone who replied to you thinks the opposite, and have already provided solutions to your question (tweaked default start up file / opening blender in a specific template, etc…) yet you are always speaking on new users behalf.
Please just leave them alone, they probably will find their way on their own.
