“select” is most basic and important future about every-3d workflow. And I understand why blender 2.8 add new active tools, with good icons. but I hope, it is not only about design, It need to be effective when user use as main tool.
Current designe is cool enough, but I think there are some intractable ways about selection with Active tool.
1 ,border selection can “Add, subtract, Difference, intersetct” as new options.it is really useful.
but why those button are not located in 3d view window header, but fix on the left side second menu?
we often change window . eg, I set 3d view window right side pane, then try to work in edit mode with border selection tool. but these otpion buttons are top left corner. (I actually lost once, where they have gone,)
It may better at least near by work space which we use selection tool.
2 it only work when we use “Active tool” as Box selection.
but it not work when I use short-cut (B) to Border selection. to exchange Circle selection(C)
- when user set Active tool as border selection, we can still use Circle selection. from short-cut (C)
but we can not use rasso selection. anymore.
And I think, it is not so reasonable, Only border selection tool separated as active tool, as if it is main selection tool of blender 2.8.
if we need border selection tool as Active tool with icon. There should be “circle selection tool” and "rasso selection (free selection) tool) as Active tool with icon, and every selection tool are expected to use “add subtract, Difference, intersect” as same as border selection tool.
Or I may prefer, there is only one active" selection tool" but it can exchange “border >circle> rasso” mode with drop down menu. or simply use short cut as same as before. then which mode we used, all “add, subtract, difference, intersect” work with current mode. (and can add short-cut)
I do not know, why border selection seems treated so special, (because it is only one mode which have new icon, and now it seems default-active tool)
