This is only a styling consideration. When widget emboss feature is activated, it give to the UI buttons a underlying effect. Also this feature affects the properties tabs. But tabs are indeed no buttons, so this effect make it a weird effect on the tabs. For tabs the emboss effect should be desactivated or to be inverse, like the example attached
