-if you go into keymap>window>Cycle Space Type Set you can change Shift F12 by Ctrl+shift+Tab so now you can switch between timeline and dopesheet with quite the same shortcut as the one to toggle with graph editor (Ctrl+Tab) more logical…
-the autokey icone should appear under the dopesheet because if it was activated under timeline this is still activated under dopesheet. and this is quite useful to create interpolated frames
