Hello, I would like help building Blender for Ubuntu 18.04 LTS.
I’ve followed the instructions here for the Advanced Setup (building the dependencies with install_deps). I have tried deleting the /opt/lib directory and re-building the dependencies. I have gotten Blender to build with make
in the past, but I’ve always had a lot of trouble with building on Ubuntu. I can get make lite
to build consistently, but very rarely does make
or make full
work.
I have installed the Optix libraries. I’m not sure if I’ve actually installed CUDA… nor do I know how to do this on Linux. I have never had trouble building on Windows, including CUDA/Cycles.
I am running:
sudo ./install_deps.sh --force-python --force-numpy --force-oidn
because I’ve had difficulty getting certain addons working even in successful builds. I’ve added --force-oidn
because I want to try this hack for myself. I added --force-oidn
because I noticed that make
wasn’t finding the OpenImageDeNoise library.
Here’s the build log:
Configuring Blender in "/home/theangerspecialist/blender-git/build_linux" ...
-- #define OPENEXR_VERSION_STRING "2.4.0"
-- Could NOT find OpenCOLLADA (missing: _opencollada_LIBRARIES _opencollada_INCLUDES)
-- Found OPENVDB: /opt/lib/openvdb/lib/libopenvdb.so
-- Found ALEMBIC: /opt/lib/alembic/lib/libAlembic.a
-- Found USD: /opt/lib/usd/lib/libusd_ms.so
-- Boost version: 1.65.1
-- Found the following Boost libraries:
-- filesystem
-- regex
-- thread
-- date_time
-- wave
-- locale
-- iostreams
-- system
-- chrono
-- atomic
-- serialization
-- Could NOT find OpenImageDenoise (missing: OPENIMAGEDENOISE_LIBRARY OPENIMAGEDENOISE_INCLUDE_DIR)
-- OpenImageDenoise not found
-- Found LLVM: /usr/lib/x86_64-linux-gnu/libLLVM-6.0.so
-- Found OpenMP_C: -fopenmp
-- Found OpenMP_CXX: -fopenmp
-- Unsupported CFLAG: -Wabsolute-value
-- numpy found at '/usr/lib/python3/dist-packages'
-- requests found at '/usr/lib/python3/dist-packages'
-- Disabling render tests because OIIO idiff does not exist
-- Configuring done
-- Generating done
-- Build files have been written to: /home/theangerspecialist/blender-git/build_linux
Building Blender ...
make -s -C "/home/theangerspecialist/blender-git/build_linux" -j 16 install
[ 0%] Built target bf_intern_numaapi
[ 0%] Built target bf_intern_string
[ 0%] Built target bf_intern_clog
[ 0%] Built target bf_intern_glew_mx
[ 1%] Built target datatoc
[ 1%] Built target bf_intern_mikktspace
[ 1%] Built target bf_intern_audaspace
[ 1%] Built target bf_intern_memutil
[ 1%] Built target bf_intern_guardedalloc
[ 1%] Built target bf_dna_blenlib
[ 2%] Built target bf_intern_ghost
[ 2%] Built target bf_intern_dualcon
[ 2%] Built target bf_intern_eigen
[ 2%] Built target bf_intern_iksolver
[ 2%] Built target extern_cuew
[ 2%] Built target bf_intern_locale
[ 2%] Built target extern_clew
[ 2%] Built target bf_intern_rigidbody
[ 2%] Built target bf_intern_libc_compat
[ 2%] Built target makesdna
[ 2%] Built target cycles_subd
[ 3%] Built target bf_intern_openvdb
[ 3%] Built target bf_intern_mantaflow
[ 5%] Built target cycles_osl_shaders
[ 6%] Built target cycles_util
[ 6%] Built target extern_curve_fit_nd
[ 6%] Built target bf_intern_quadriflow
[ 6%] Built target extern_rangetree
[ 6%] Built target extern_wcwidth
[ 6%] Built target extern_binreloc
[ 6%] Built target extern_glew
[ 6%] Built target extern_minilzo
[ 6%] Built target extern_lzma
[ 7%] Built target bf_intern_itasc
[ 7%] Built target extern_xdnd
[ 7%] Built target extern_glog
[ 7%] Built target extern_gflags
[ 8%] Built target dracoenc
[ 8%] Building CXX object extern/audaspace/CMakeFiles/audaspace.dir/plugins/sdl/SDLDevice.cpp.o
[ 11%] Built target extern_mantaflow
[ 11%] Built target extern_quadriflow
[ 15%] Built target extern_bullet
[ 15%] Built target datatoc_icon
[ 16%] Built target bf_intern_libmv
extern/audaspace/CMakeFiles/audaspace.dir/build.make:2774: recipe for target 'extern/audaspace/CMakeFiles/audaspace.dir/plugins/sdl/SDLDevice.cpp.o' failed
CMakeFiles/Makefile2:3037: recipe for target 'extern/audaspace/CMakeFiles/audaspace.dir/all' failed
[ 19%] Built target extern_ceres
Scanning dependencies of target bf_editor_mask
Scanning dependencies of target bf_editor_curve
[ 19%] Building C object source/blender/editors/mask/CMakeFiles/bf_editor_mask.dir/mask_add.c.o
[ 19%] Building C object source/blender/editors/mask/CMakeFiles/bf_editor_mask.dir/mask_edit.c.o
[ 19%] Building C object source/blender/editors/mask/CMakeFiles/bf_editor_mask.dir/mask_draw.c.o
Scanning dependencies of target bf_editor_gizmo_library
Scanning dependencies of target bf_editor_physics
[ 19%] Building C object source/blender/editors/curve/CMakeFiles/bf_editor_curve.dir/curve_ops.c.o
[ 19%] Building C object source/blender/editors/gizmo_library/CMakeFiles/bf_editor_gizmo_library.dir/gizmo_draw_utils.c.o
[ 19%] Building C object source/blender/editors/physics/CMakeFiles/bf_editor_physics.dir/dynamicpaint_ops.c.o
Scanning dependencies of target bf_editor_io
Scanning dependencies of target bf_editor_lattice
[ 19%] Building C object source/blender/editors/io/CMakeFiles/bf_editor_io.dir/io_alembic.c.o
Scanning dependencies of target bf_editor_metaball
[ 19%] Building C object source/blender/editors/lattice/CMakeFiles/bf_editor_lattice.dir/editlattice_select.c.o
[ 19%] Building C object source/blender/editors/metaball/CMakeFiles/bf_editor_metaball.dir/editmball_undo.c.o
Scanning dependencies of target bf_editor_render
[ 19%] Building C object source/blender/editors/render/CMakeFiles/bf_editor_render.dir/render_internal.c.o
[ 19%] Building C object source/blender/editors/curve/CMakeFiles/bf_editor_curve.dir/editcurve.c.o
[ 19%] Building C object source/blender/editors/curve/CMakeFiles/bf_editor_curve.dir/editcurve_add.c.o
[ 19%] Building C object source/blender/editors/metaball/CMakeFiles/bf_editor_metaball.dir/mball_edit.c.o
[ 19%] Building C object source/blender/editors/gizmo_library/CMakeFiles/bf_editor_gizmo_library.dir/gizmo_library_presets.c.o
[ 19%] Building C object source/blender/editors/gizmo_library/CMakeFiles/bf_editor_gizmo_library.dir/gizmo_library_utils.c.o
[ 19%] Building C object source/blender/editors/gizmo_library/CMakeFiles/bf_editor_gizmo_library.dir/gizmo_types/arrow3d_gizmo.c.o
[ 19%] Building C object source/blender/editors/physics/CMakeFiles/bf_editor_physics.dir/particle_boids.c.o
[ 19%] Building C object source/blender/editors/io/CMakeFiles/bf_editor_io.dir/io_cache.c.o
Scanning dependencies of target bf_editor_object
[ 19%] Building C object source/blender/editors/io/CMakeFiles/bf_editor_io.dir/io_collada.c.o
[ 19%] Building C object source/blender/editors/lattice/CMakeFiles/bf_editor_lattice.dir/editlattice_tools.c.o
[ 19%] Building C object source/blender/editors/lattice/CMakeFiles/bf_editor_lattice.dir/editlattice_undo.c.o
[ 19%] Building C object source/blender/editors/object/CMakeFiles/bf_editor_object.dir/object_add.c.o
[ 19%] Building C object source/blender/editors/mask/CMakeFiles/bf_editor_mask.dir/mask_editaction.c.o
Scanning dependencies of target bf_editor_armature
[ 19%] Building C object source/blender/editors/mask/CMakeFiles/bf_editor_mask.dir/mask_ops.c.o
[ 19%] Building C object source/blender/editors/armature/CMakeFiles/bf_editor_armature.dir/armature_add.c.o
Scanning dependencies of target bf_editor_animation
Scanning dependencies of target bf_editor_gpencil
[ 19%] Building C object source/blender/editors/animation/CMakeFiles/bf_editor_animation.dir/anim_channels_defines.c.o
Scanning dependencies of target bf_editor_interface
Scanning dependencies of target bf_editor_mesh
[ 19%] Building C object source/blender/editors/gpencil/CMakeFiles/bf_editor_gpencil.dir/annotate_draw.c.o
[ 19%] Building C object source/blender/editors/metaball/CMakeFiles/bf_editor_metaball.dir/mball_ops.c.o
[ 19%] Building C object source/blender/editors/io/CMakeFiles/bf_editor_io.dir/io_ops.c.o
[ 19%] Building C object source/blender/editors/render/CMakeFiles/bf_editor_render.dir/render_opengl.c.o
[ 19%] Building C object source/blender/editors/interface/CMakeFiles/bf_editor_interface.dir/interface.c.o
[ 19%] Building C object source/blender/editors/mesh/CMakeFiles/bf_editor_mesh.dir/editface.c.o
[ 19%] Building C object source/blender/editors/mesh/CMakeFiles/bf_editor_mesh.dir/editmesh_add.c.o
[ 19%] Building C object source/blender/editors/mesh/CMakeFiles/bf_editor_mesh.dir/editmesh_add_gizmo.c.o
[ 19%] Building C object source/blender/editors/physics/CMakeFiles/bf_editor_physics.dir/particle_edit.c.o
[ 19%] Linking C static library ../../../../lib/libbf_editor_metaball.a
[ 19%] Building C object source/blender/editors/io/CMakeFiles/bf_editor_io.dir/io_usd.c.o
[ 19%] Building C object source/blender/editors/gizmo_library/CMakeFiles/bf_editor_gizmo_library.dir/gizmo_types/blank3d_gizmo.c.o
[ 19%] Building C object source/blender/editors/lattice/CMakeFiles/bf_editor_lattice.dir/lattice_ops.c.o
[ 19%] Built target bf_editor_metaball
[ 19%] Building C object source/blender/editors/gizmo_library/CMakeFiles/bf_editor_gizmo_library.dir/gizmo_types/button2d_gizmo.c.o
[ 19%] Building C object source/blender/editors/armature/CMakeFiles/bf_editor_armature.dir/armature_edit.c.o
[ 19%] Linking C static library ../../../../lib/libbf_editor_lattice.a
[ 19%] Linking C static library ../../../../lib/libbf_editor_io.a
[ 19%] Built target bf_editor_lattice
[ 19%] Building C object source/blender/editors/armature/CMakeFiles/bf_editor_armature.dir/armature_naming.c.o
[ 19%] Built target bf_editor_io
[ 19%] Building C object source/blender/editors/armature/CMakeFiles/bf_editor_armature.dir/armature_ops.c.o
[ 19%] Building C object source/blender/editors/armature/CMakeFiles/bf_editor_armature.dir/armature_relations.c.o
[ 19%] Building C object source/blender/editors/gizmo_library/CMakeFiles/bf_editor_gizmo_library.dir/gizmo_types/cage2d_gizmo.c.o
[ 19%] Building C object source/blender/editors/gpencil/CMakeFiles/bf_editor_gpencil.dir/annotate_paint.c.o
[ 19%] Building C object source/blender/editors/gpencil/CMakeFiles/bf_editor_gpencil.dir/drawgpencil.c.o
[ 19%] Building C object source/blender/editors/gpencil/CMakeFiles/bf_editor_gpencil.dir/editaction_gpencil.c.o
[ 19%] Building C object source/blender/editors/gpencil/CMakeFiles/bf_editor_gpencil.dir/gpencil_add_monkey.c.o
[ 19%] Building C object source/blender/editors/mask/CMakeFiles/bf_editor_mask.dir/mask_query.c.o
[ 19%] Building C object source/blender/editors/render/CMakeFiles/bf_editor_render.dir/render_ops.c.o
[ 19%] Building C object source/blender/editors/render/CMakeFiles/bf_editor_render.dir/render_preview.c.o
[ 19%] Building C object source/blender/editors/gpencil/CMakeFiles/bf_editor_gpencil.dir/gpencil_add_stroke.c.o
[ 19%] Building C object source/blender/editors/gpencil/CMakeFiles/bf_editor_gpencil.dir/gpencil_armature.c.o
[ 19%] Building C object source/blender/editors/render/CMakeFiles/bf_editor_render.dir/render_update.c.o
[ 19%] Building C object source/blender/editors/render/CMakeFiles/bf_editor_render.dir/render_shading.c.o
[ 19%] Building C object source/blender/editors/armature/CMakeFiles/bf_editor_armature.dir/armature_skinning.c.o
[ 19%] Building C object source/blender/editors/armature/CMakeFiles/bf_editor_armature.dir/armature_select.c.o
[ 19%] Building C object source/blender/editors/mesh/CMakeFiles/bf_editor_mesh.dir/editmesh_automerge.c.o
[ 19%] Building C object source/blender/editors/object/CMakeFiles/bf_editor_object.dir/object_bake.c.o
[ 19%] Building C object source/blender/editors/mask/CMakeFiles/bf_editor_mask.dir/mask_relationships.c.o
[ 19%] Building C object source/blender/editors/mask/CMakeFiles/bf_editor_mask.dir/mask_select.c.o
[ 19%] Building C object source/blender/editors/gizmo_library/CMakeFiles/bf_editor_gizmo_library.dir/gizmo_types/cage3d_gizmo.c.o
[ 19%] Building C object source/blender/editors/mesh/CMakeFiles/bf_editor_mesh.dir/editmesh_bisect.c.o
[ 19%] Building C object source/blender/editors/mesh/CMakeFiles/bf_editor_mesh.dir/editmesh_bevel.c.o
[ 19%] Building C object source/blender/editors/animation/CMakeFiles/bf_editor_animation.dir/anim_channels_edit.c.o
[ 19%] Building C object source/blender/editors/mask/CMakeFiles/bf_editor_mask.dir/mask_shapekey.c.o
[ 19%] Building C object source/blender/editors/object/CMakeFiles/bf_editor_object.dir/object_bake_api.c.o
[ 19%] Building C object source/blender/editors/gpencil/CMakeFiles/bf_editor_gpencil.dir/gpencil_convert.c.o
[ 19%] Building C object source/blender/editors/armature/CMakeFiles/bf_editor_armature.dir/armature_utils.c.o
[ 19%] Building C object source/blender/editors/object/CMakeFiles/bf_editor_object.dir/object_collection.c.o
[ 19%] Building C object source/blender/editors/gizmo_library/CMakeFiles/bf_editor_gizmo_library.dir/gizmo_types/dial3d_gizmo.c.o
[ 19%] Building C object source/blender/editors/gizmo_library/CMakeFiles/bf_editor_gizmo_library.dir/gizmo_types/move3d_gizmo.c.o
[ 19%] Building C object source/blender/editors/gpencil/CMakeFiles/bf_editor_gpencil.dir/gpencil_data.c.o
[ 19%] Linking C static library ../../../../lib/libbf_editor_mask.a
[ 19%] Building C object source/blender/editors/gpencil/CMakeFiles/bf_editor_gpencil.dir/gpencil_edit.c.o
[ 19%] Building C object source/blender/editors/mesh/CMakeFiles/bf_editor_mesh.dir/editmesh_extrude.c.o
[ 19%] Building C object source/blender/editors/render/CMakeFiles/bf_editor_render.dir/render_view.c.o
[ 19%] Built target bf_editor_mask
[ 19%] Building C object source/blender/editors/armature/CMakeFiles/bf_editor_armature.dir/editarmature_undo.c.o
[ 19%] Building C object source/blender/editors/armature/CMakeFiles/bf_editor_armature.dir/meshlaplacian.c.o
[ 19%] Building C object source/blender/editors/object/CMakeFiles/bf_editor_object.dir/object_constraint.c.o
[ 19%] Building C object source/blender/editors/object/CMakeFiles/bf_editor_object.dir/object_data_transfer.c.o
[ 19%] Building C object source/blender/editors/object/CMakeFiles/bf_editor_object.dir/object_data_transform.c.o
[ 19%] Linking C static library ../../../../lib/libbf_editor_render.a
[ 19%] Building C object source/blender/editors/object/CMakeFiles/bf_editor_object.dir/object_edit.c.o
[ 19%] Building C object source/blender/editors/gizmo_library/CMakeFiles/bf_editor_gizmo_library.dir/gizmo_types/primitive3d_gizmo.c.o
[ 19%] Building C object source/blender/editors/animation/CMakeFiles/bf_editor_animation.dir/anim_deps.c.o
[ 19%] Built target bf_editor_render
[ 19%] Building C object source/blender/editors/object/CMakeFiles/bf_editor_object.dir/object_facemap_ops.c.o
[ 19%] Building C object source/blender/editors/interface/CMakeFiles/bf_editor_interface.dir/interface_anim.c.o
[ 19%] Building C object source/blender/editors/interface/CMakeFiles/bf_editor_interface.dir/interface_context_menu.c.o
[ 19%] Building C object source/blender/editors/animation/CMakeFiles/bf_editor_animation.dir/anim_draw.c.o
[ 19%] Building C object source/blender/editors/mesh/CMakeFiles/bf_editor_mesh.dir/editmesh_extrude_spin.c.o
[ 19%] Building C object source/blender/editors/mesh/CMakeFiles/bf_editor_mesh.dir/editmesh_extrude_screw.c.o
[ 19%] Building C object source/blender/editors/object/CMakeFiles/bf_editor_object.dir/object_gpencil_modifier.c.o
[ 19%] Linking C static library ../../../../lib/libbf_editor_gizmo_library.a
[ 19%] Building C object source/blender/editors/object/CMakeFiles/bf_editor_object.dir/object_hook.c.o
[ 19%] Building C object source/blender/editors/animation/CMakeFiles/bf_editor_animation.dir/anim_filter.c.o
[ 19%] Building C object source/blender/editors/object/CMakeFiles/bf_editor_object.dir/object_modes.c.o
[ 19%] Built target bf_editor_gizmo_library
[ 19%] Building C object source/blender/editors/object/CMakeFiles/bf_editor_object.dir/object_modifier.c.o
[ 19%] Building C object source/blender/editors/physics/CMakeFiles/bf_editor_physics.dir/particle_edit_undo.c.o
[ 19%] Building C object source/blender/editors/gpencil/CMakeFiles/bf_editor_gpencil.dir/gpencil_fill.c.o
[ 19%] Building C object source/blender/editors/mesh/CMakeFiles/bf_editor_mesh.dir/editmesh_extrude_spin_gizmo.c.o
[ 19%] Building C object source/blender/editors/interface/CMakeFiles/bf_editor_interface.dir/interface_draw.c.o
[ 19%] Building C object source/blender/editors/object/CMakeFiles/bf_editor_object.dir/object_random.c.o
[ 19%] Building C object source/blender/editors/object/CMakeFiles/bf_editor_object.dir/object_ops.c.o
[ 19%] Building C object source/blender/editors/interface/CMakeFiles/bf_editor_interface.dir/interface_eyedropper.c.o
[ 19%] Building C object source/blender/editors/interface/CMakeFiles/bf_editor_interface.dir/interface_eyedropper_color.c.o
[ 19%] Building C object source/blender/editors/interface/CMakeFiles/bf_editor_interface.dir/interface_eyedropper_colorband.c.o
[ 19%] Building C object source/blender/editors/interface/CMakeFiles/bf_editor_interface.dir/interface_eyedropper_datablock.c.o
[ 19%] Building C object source/blender/editors/physics/CMakeFiles/bf_editor_physics.dir/particle_object.c.o
[ 19%] Building C object source/blender/editors/object/CMakeFiles/bf_editor_object.dir/object_relations.c.o
[ 19%] Building C object source/blender/editors/object/CMakeFiles/bf_editor_object.dir/object_remesh.c.o
[ 19%] Building C object source/blender/editors/physics/CMakeFiles/bf_editor_physics.dir/physics_fluid.c.o
[ 19%] Building C object source/blender/editors/curve/CMakeFiles/bf_editor_curve.dir/editcurve_paint.c.o
[ 20%] Building C object source/blender/editors/armature/CMakeFiles/bf_editor_armature.dir/pose_edit.c.o
[ 20%] Building C object source/blender/editors/curve/CMakeFiles/bf_editor_curve.dir/editcurve_query.c.o
[ 20%] Building C object source/blender/editors/curve/CMakeFiles/bf_editor_curve.dir/editcurve_undo.c.o
[ 20%] Building C object source/blender/editors/curve/CMakeFiles/bf_editor_curve.dir/editcurve_select.c.o
[ 20%] Building C object source/blender/editors/curve/CMakeFiles/bf_editor_curve.dir/editfont.c.o
[ 20%] Building C object source/blender/editors/mesh/CMakeFiles/bf_editor_mesh.dir/editmesh_inset.c.o
[ 20%] Building C object source/blender/editors/curve/CMakeFiles/bf_editor_curve.dir/editfont_undo.c.o
[ 20%] Building C object source/blender/editors/mesh/CMakeFiles/bf_editor_mesh.dir/editmesh_intersect.c.o
[ 20%] Building C object source/blender/editors/animation/CMakeFiles/bf_editor_animation.dir/anim_ipo_utils.c.o
[ 20%] Building C object source/blender/editors/gpencil/CMakeFiles/bf_editor_gpencil.dir/gpencil_interpolate.c.o
[ 20%] Building C object source/blender/editors/physics/CMakeFiles/bf_editor_physics.dir/physics_ops.c.o
[ 20%] Building C object source/blender/editors/gpencil/CMakeFiles/bf_editor_gpencil.dir/gpencil_merge.c.o
[ 20%] Building C object source/blender/editors/object/CMakeFiles/bf_editor_object.dir/object_select.c.o
[ 20%] Building C object source/blender/editors/object/CMakeFiles/bf_editor_object.dir/object_shader_fx.c.o
[ 20%] Building C object source/blender/editors/object/CMakeFiles/bf_editor_object.dir/object_shapekey.c.o
[ 20%] Building C object source/blender/editors/object/CMakeFiles/bf_editor_object.dir/object_transform.c.o
[ 20%] Building C object source/blender/editors/armature/CMakeFiles/bf_editor_armature.dir/pose_group.c.o
[ 20%] Building C object source/blender/editors/physics/CMakeFiles/bf_editor_physics.dir/physics_pointcache.c.o
[ 20%] Building C object source/blender/editors/animation/CMakeFiles/bf_editor_animation.dir/anim_markers.c.o
[ 20%] Building C object source/blender/editors/physics/CMakeFiles/bf_editor_physics.dir/rigidbody_constraint.c.o
[ 20%] Building C object source/blender/editors/physics/CMakeFiles/bf_editor_physics.dir/rigidbody_object.c.o
[ 20%] Building C object source/blender/editors/armature/CMakeFiles/bf_editor_armature.dir/pose_lib.c.o
[ 20%] Building C object source/blender/editors/mesh/CMakeFiles/bf_editor_mesh.dir/editmesh_knife.c.o
[ 20%] Building C object source/blender/editors/object/CMakeFiles/bf_editor_object.dir/object_utils.c.o
[ 20%] Building C object source/blender/editors/physics/CMakeFiles/bf_editor_physics.dir/rigidbody_world.c.o
[ 20%] Building C object source/blender/editors/interface/CMakeFiles/bf_editor_interface.dir/interface_eyedropper_depth.c.o
[ 20%] Building C object source/blender/editors/armature/CMakeFiles/bf_editor_armature.dir/pose_select.c.o
[ 20%] Building C object source/blender/editors/interface/CMakeFiles/bf_editor_interface.dir/interface_eyedropper_driver.c.o
[ 20%] Building C object source/blender/editors/armature/CMakeFiles/bf_editor_armature.dir/pose_slide.c.o
[ 20%] Building C object source/blender/editors/gpencil/CMakeFiles/bf_editor_gpencil.dir/gpencil_ops.c.o
[ 20%] Building C object source/blender/editors/interface/CMakeFiles/bf_editor_interface.dir/interface_eyedropper_gpencil_color.c.o
[ 20%] Building C object source/blender/editors/mesh/CMakeFiles/bf_editor_mesh.dir/editmesh_knife_project.c.o
[ 20%] Linking C static library ../../../../lib/libbf_editor_curve.a
[ 20%] Building C object source/blender/editors/mesh/CMakeFiles/bf_editor_mesh.dir/editmesh_loopcut.c.o
[ 20%] Linking C static library ../../../../lib/libbf_editor_physics.a
[ 20%] Built target bf_editor_curve
[ 20%] Building C object source/blender/editors/gpencil/CMakeFiles/bf_editor_gpencil.dir/gpencil_ops_versioning.c.o
[ 20%] Built target bf_editor_physics
[ 20%] Building C object source/blender/editors/mesh/CMakeFiles/bf_editor_mesh.dir/editmesh_mask_extract.c.o
[ 20%] Building C object source/blender/editors/mesh/CMakeFiles/bf_editor_mesh.dir/editmesh_path.c.o
[ 20%] Building C object source/blender/editors/gpencil/CMakeFiles/bf_editor_gpencil.dir/gpencil_paint.c.o
[ 20%] Building C object source/blender/editors/mesh/CMakeFiles/bf_editor_mesh.dir/editmesh_polybuild.c.o
[ 20%] Building C object source/blender/editors/gpencil/CMakeFiles/bf_editor_gpencil.dir/gpencil_primitive.c.o
[ 20%] Building C object source/blender/editors/interface/CMakeFiles/bf_editor_interface.dir/interface_handlers.c.o
[ 20%] Building C object source/blender/editors/interface/CMakeFiles/bf_editor_interface.dir/interface_icons.c.o
[ 20%] Building C object source/blender/editors/interface/CMakeFiles/bf_editor_interface.dir/interface_icons_event.c.o
[ 20%] Building C object source/blender/editors/animation/CMakeFiles/bf_editor_animation.dir/anim_motion_paths.c.o
[ 20%] Building C object source/blender/editors/animation/CMakeFiles/bf_editor_animation.dir/anim_ops.c.o
[ 20%] Building C object source/blender/editors/animation/CMakeFiles/bf_editor_animation.dir/drivers.c.o
[ 21%] Building C object source/blender/editors/mesh/CMakeFiles/bf_editor_mesh.dir/editmesh_preselect_edgering.c.o
[ 21%] Building C object source/blender/editors/object/CMakeFiles/bf_editor_object.dir/object_vgroup.c.o
[ 21%] Building C object source/blender/editors/mesh/CMakeFiles/bf_editor_mesh.dir/editmesh_preselect_elem.c.o
[ 21%] Building C object source/blender/editors/armature/CMakeFiles/bf_editor_armature.dir/pose_utils.c.o
[ 21%] Building C object source/blender/editors/armature/CMakeFiles/bf_editor_armature.dir/pose_transform.c.o
[ 21%] Building C object source/blender/editors/interface/CMakeFiles/bf_editor_interface.dir/interface_layout.c.o
[ 21%] Building C object source/blender/editors/object/CMakeFiles/bf_editor_object.dir/object_volume.c.o
[ 21%] Building C object source/blender/editors/gpencil/CMakeFiles/bf_editor_gpencil.dir/gpencil_sculpt_paint.c.o
[ 21%] Building C object source/blender/editors/animation/CMakeFiles/bf_editor_animation.dir/fmodifier_ui.c.o
[ 21%] Building C object source/blender/editors/gpencil/CMakeFiles/bf_editor_gpencil.dir/gpencil_select.c.o
[ 21%] Building C object source/blender/editors/animation/CMakeFiles/bf_editor_animation.dir/keyframes_draw.c.o
[ 21%] Building C object source/blender/editors/mesh/CMakeFiles/bf_editor_mesh.dir/editmesh_rip.c.o
[ 21%] Building C object source/blender/editors/mesh/CMakeFiles/bf_editor_mesh.dir/editmesh_rip_edge.c.o
[ 21%] Building C object source/blender/editors/animation/CMakeFiles/bf_editor_animation.dir/keyframes_edit.c.o
[ 21%] Building C object source/blender/editors/mesh/CMakeFiles/bf_editor_mesh.dir/editmesh_select.c.o
[ 22%] Building C object source/blender/editors/gpencil/CMakeFiles/bf_editor_gpencil.dir/gpencil_undo.c.o
[ 22%] Building C object source/blender/editors/animation/CMakeFiles/bf_editor_animation.dir/keyframes_general.c.o
[ 22%] Linking C static library ../../../../lib/libbf_editor_armature.a
[ 22%] Building C object source/blender/editors/mesh/CMakeFiles/bf_editor_mesh.dir/editmesh_select_similar.c.o
[ 22%] Building C object source/blender/editors/mesh/CMakeFiles/bf_editor_mesh.dir/editmesh_tools.c.o
[ 22%] Building C object source/blender/editors/mesh/CMakeFiles/bf_editor_mesh.dir/editmesh_undo.c.o
[ 22%] Building C object source/blender/editors/mesh/CMakeFiles/bf_editor_mesh.dir/editmesh_utils.c.o
[ 22%] Built target bf_editor_armature
[ 22%] Building C object source/blender/editors/mesh/CMakeFiles/bf_editor_mesh.dir/mesh_data.c.o
[ 22%] Building C object source/blender/editors/mesh/CMakeFiles/bf_editor_mesh.dir/mesh_mirror.c.o
[ 22%] Building C object source/blender/editors/interface/CMakeFiles/bf_editor_interface.dir/interface_ops.c.o
[ 22%] Building C object source/blender/editors/interface/CMakeFiles/bf_editor_interface.dir/interface_panel.c.o
[ 22%] Building C object source/blender/editors/interface/CMakeFiles/bf_editor_interface.dir/interface_query.c.o
[ 22%] Building C object source/blender/editors/gpencil/CMakeFiles/bf_editor_gpencil.dir/gpencil_utils.c.o
[ 22%] Building C object source/blender/editors/mesh/CMakeFiles/bf_editor_mesh.dir/mesh_ops.c.o
[ 22%] Building C object source/blender/editors/animation/CMakeFiles/bf_editor_animation.dir/keyframing.c.o
[ 22%] Building C object source/blender/editors/mesh/CMakeFiles/bf_editor_mesh.dir/meshtools.c.o
[ 22%] Building C object source/blender/editors/animation/CMakeFiles/bf_editor_animation.dir/keyingsets.c.o
[ 22%] Building C object source/blender/editors/animation/CMakeFiles/bf_editor_animation.dir/time_scrub_ui.c.o
[ 22%] Building C object source/blender/editors/gpencil/CMakeFiles/bf_editor_gpencil.dir/gpencil_uv.c.o
[ 22%] Building C object source/blender/editors/interface/CMakeFiles/bf_editor_interface.dir/interface_region_color_picker.c.o
[ 22%] Building C object source/blender/editors/object/CMakeFiles/bf_editor_object.dir/object_warp.c.o
[ 22%] Building C object source/blender/editors/interface/CMakeFiles/bf_editor_interface.dir/interface_region_hud.c.o
[ 22%] Building C object source/blender/editors/interface/CMakeFiles/bf_editor_interface.dir/interface_region_menu_pie.c.o
[ 22%] Building C object source/blender/editors/interface/CMakeFiles/bf_editor_interface.dir/interface_region_menu_popup.c.o
[ 22%] Building C object source/blender/editors/gpencil/CMakeFiles/bf_editor_gpencil.dir/gpencil_vertex_ops.c.o
[ 22%] Building C object source/blender/editors/interface/CMakeFiles/bf_editor_interface.dir/interface_region_popover.c.o
[ 23%] Linking C static library ../../../../lib/libbf_editor_object.a
[ 23%] Built target bf_editor_object
[ 23%] Building C object source/blender/editors/gpencil/CMakeFiles/bf_editor_gpencil.dir/gpencil_vertex_paint.c.o
[ 23%] Building C object source/blender/editors/interface/CMakeFiles/bf_editor_interface.dir/interface_region_popup.c.o
[ 23%] Building C object source/blender/editors/interface/CMakeFiles/bf_editor_interface.dir/interface_region_search.c.o
[ 23%] Building C object source/blender/editors/interface/CMakeFiles/bf_editor_interface.dir/interface_region_tooltip.c.o
[ 23%] Building C object source/blender/editors/interface/CMakeFiles/bf_editor_interface.dir/interface_regions.c.o
[ 23%] Building C object source/blender/editors/interface/CMakeFiles/bf_editor_interface.dir/interface_templates.c.o
[ 23%] Building C object source/blender/editors/interface/CMakeFiles/bf_editor_interface.dir/interface_utils.c.o
[ 23%] Linking C static library ../../../../lib/libbf_editor_animation.a
[ 23%] Building C object source/blender/editors/gpencil/CMakeFiles/bf_editor_gpencil.dir/gpencil_weight_paint.c.o
[ 23%] Building C object source/blender/editors/interface/CMakeFiles/bf_editor_interface.dir/resources.c.o
[ 23%] Building C object source/blender/editors/interface/CMakeFiles/bf_editor_interface.dir/view2d.c.o
[ 23%] Built target bf_editor_animation
[ 24%] Building C object source/blender/editors/interface/CMakeFiles/bf_editor_interface.dir/view2d_gizmo_navigate.c.o
[ 24%] Building C object source/blender/editors/interface/CMakeFiles/bf_editor_interface.dir/view2d_draw.c.o
[ 24%] Building C object source/blender/editors/interface/CMakeFiles/bf_editor_interface.dir/view2d_ops.c.o
[ 24%] Linking C static library ../../../../lib/libbf_editor_gpencil.a
[ 24%] Built target bf_editor_gpencil
[ 24%] Linking C static library ../../../../lib/libbf_editor_mesh.a
[ 24%] Linking C static library ../../../../lib/libbf_editor_interface.a
[ 24%] Built target bf_editor_mesh
[ 24%] Built target bf_editor_interface
Makefile:162: recipe for target 'all' failed
GNUmakefile:310: recipe for target 'all' failed
Also worth noting – it looks like Blender can’t find SDL? I can’t seem to find a package for this, which is odd. It’s also not finding OpenCollada, even though I’m sure install_deps.sh is making that. I used --show-deps
to get this list of packages that I should be able to get from my distro:
Basics of dev environment (cmake, gcc, svn , git, ...).
* libjpeg, libpng, libtiff, [openjpeg2], [libopenal].
* libx11, libxcursor, libxi, libxrandr, libxinerama (and other libx... as needed).
* libsqlite3, libbz2, libssl, libfftw3, libxml2, libtinyxml, yasm, libyaml-cpp.
* libsdl1.2, libglew, [libglewmx].
Then I tried to install these packages… here’s what I get:
theangerspecialist@theangerspecialist-MS-7B98:~/blender-git/blender/build_files/build_environment$ sudo apt install libjpeg libpng libtiff openjpeg2 libopenal libx11 libxcursor libxi libxrandr libxinerama libsqlite3 libbz2 libssl libfftw3 libxml2 libtinyxml yasm libyaml-cpp libsdl1.2 libglew libglewmx
Reading package lists... Done
Building dependency tree
Reading state information... Done
Package libbz2 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
bzip2 bzip2:i386
Package libsdl1.2 is not available, but is referred to by another package.
E: Unable to locate package libjpeg
E: Unable to locate package libpng
E: Unable to locate package libtiff
E: Unable to locate package openjpeg2
E: Unable to locate package libopenal
E: Unable to locate package libx11
E: Unable to locate package libxcursor
E: Unable to locate package libxi
E: Unable to locate package libxrandr
E: Unable to locate package libxinerama
E: Unable to locate package libsqlite3
E: Package 'libbz2' has no installation candidate
E: Unable to locate package libssl
E: Unable to locate package libfftw3
E: Unable to locate package libtinyxml
E: Unable to locate package libyaml-cpp
E: Package 'libsdl1.2' has no installation candidate
E: Unable to locate package libglew
E: Unable to locate package libglewmx
I’m really at a loss. Any help would be appreciated!
