Hi.
About defaults.
Since new AI denoisers handle fireflies correctly, is it worth it to continue clamping indirect light by default? I also think I remember reading that default Indirect Light clamping=10 was causing some problems with Nishita Sky Texture. (Edit: Default Clamp)
About Light Paths, I have noticed some times that for glass/transmission materials to look better it needs a bit more Glossy and Transmission bounces than the current default values.
I would personally be in favor of the indirect light clamp being increased. However, I believe setting the value to 0 (no clamping) is still a bad idea. From limited testing a value like 50 seems to be better. As it still reduces fireflies but doesn’t decrease the brightness as much as 10.
The reason I’m suggesting leaving clamping on is to continue to reduce fireflies is for people who do not wish to use denoising, or for people who wish to mix the noisy render result with the denoised result in compositing for “artistic effect”. And with adaptive sampling being the default, you can get some issues with fireflies that could potentially lead to denoising artifacts if no clamping was used.
I have heard several times people complaining to me how Cycles volume scatter is dirty and heavy, then I asked them whether they set the light bounce higher, they would tell me they never touched it, didn’t even know it exists. So I think it makes sense to have the default be higher.
While I agree that 4 glossy bounces is not enough for rendering glass, 10 bounces is usually more then enough even for ill cases. It would be cool to make trapped rays escape glass after the last bounce by default, not just them being killed causing black areas around glass lips. So far I have to repeat the same shader setup over and over. Dispersion also would be welcome, but that requires either random per ray or spectral rendering =)
Not Transparent shader I think. But generally speaking I imagine that will be the task of the future for the Spectral Cycles branch after it completes the initial merge (hopefully in 3.1 or 3.2) :
This is probably not related to the topic here so if we are to discuss more about dispersion we should better move on to the the spectral thread.
I’m looking into this, we may add it back as a pass independent of denoising.
If you’re on Windows, the Blender install folder contains a blender_debug_gpu.cmd that you can run to generate debug logs. Generally, more important than crash logs is a .blend file to reproduce the problem. And then if we still can’t reproduce, a crash log can help.
Great!! Today I was using 2.93 at work and I just came in a situation where Random Walk just didn’t work but Christensen-Burley did very easily, and I wished we could have it back in 3.0! Thanks Brecht!
Thanks for taking time to reply Brecht, It’s awesome that you are looking into it! Fingers crossed to see it back in, independent from denoising seems even more fitting to such a useful utility pass. Thank you for all your incredible work!
No clamping can produce more noise in general, not just fireflies. But default value could certainly be increased to work better with the sky texture. How much clamping will darken the image depends on exposure and lights, but value between 30 and 50 should give better results out of the box.
Hey have the bug of everytime i render Blender crashes with AS at a random position → when not when a new Tile starts. https://developer.blender.org/T92158
I have done some tests with Christinsen-Burley in 3.0 and unfortunately it does not work. Christensen-Burley produces so much noise in 3.0 that even with 10 times higher sample rates you still have a lot of noise.
@Brecht:
Are there any ideas or plans to incorporate the capabilities/features of Christensen-Burley into a variant of Random Walk (Burley)?
Is there perhaps a bug in Blender’s version of Random Walk (FR) that prevents proper light scattering and refraction. I appreciate your efforts to reintegrate Christensen-Burley in 3.0, and you have already pointed out possible problems due to the different way Cycles X works, but Blender needs the ability to correctly render translucent and transparent materials that are backlit. (light refraction and light scattering etc…)
If Christensen-Burley cannot be integrated into Cycles X, then SSS in Blender works only with significant limitations, then it urgently needs an alternative.
Maybe you should think about leaving Cycles in 3.0 next to Cycles X.
I think that if you release 3.0 in december or january, then a lot of users will complain about the missing capabilities of SSS in Blender, because that is a major regression.
Hi.
The difference between regular noise and fireflies is that regular noise is easier to decrease by increasing the render samples relatively not very much, which is not always the case with fireflies.
Clamp indirect=30 still produces some noticeable differences in lighting power compared to non-clamping, for example in the BMW scene in headlights of the car. I think clamp indirect=50 would be fine.
I did some SSS testing with Christensen-Burley on an object that looks really bad with Random walk. While it’s true that C-B needs more samples in 3.0, everything also renders much faster in Cycles X.
Here’s 2.93 render at 256spp:
So overall a bit of an improvement . Of course the issue is that the rest of the scene would have to be rendered with more samples as well, which could be a problem. For that, adaptive sampling should help, but I ran into the same problem that I reported before, where dark areas are undersampled. In this case it’s even causing denoising artifacts in the final render (dark spots in the bottom right).
