a good example would be HDA’s (basically shareable node trees with a simple front end node with only the parameters required for the end user to use the node without diving into the node tree contained within.
Say for example I build a node tree which accepts an input of objects, it then loops through each object and seperates them into containers based on their object name, then loops through all the materials of the selected objects and adds some new nodes and links. After this it selects the objects of each container one at a time, and then renders them in isolation. When it finished it sends a finished message out of the top level node, which if connected to another node will trigger that one.
I would then inside of the node tree right click on a number of parameters and choose ‘expose to top level node’.
Once complete I would then share the node to an online repository which blenders shift + a menu would have access to. A different user could then press shift + a in the node editor, select the community menu, search through by name, find my node, add the node to his node editor, connect a relevant node to my nodes input socket (in this case an object selection node), then they set a few of the parameters I’ve exposed (save location, resolution, container seperation keywords etc), make that node the active endpoint or if they like plug its output into a different node which would then perform additional tasks when my node completes.
There should definitely not be more than one node editor, instead there should be one node editor with each system (particles, textures, shaders, world, mesh edit, animation etc) being accessed by dropping down top level nodes, all of which would contain nodes relevant to the top level node. For example if you drop down a particle top level node, once inside of it, pressing shift a would bring up a list of nodes relevant to making a particle system rather than nodes relevant for compositing or creating shaders. Having top level nodes that all live in one node editor would mean that you could auutomate any number of tasks within blender just by connecting the top level nodes. For example you could have a mesh generation node connected to a mesh edit node, connected to a particle node, connected to a shader node, connected to two different render settings nodes each of which specifies a different camera to use etc, and then finally they connect to a render node to create two different renders. Top level nodes should of course be able to live within another top level node so that you can share full functionality.
The end could also if they wished dive into the node to see how it works by analysing the contained node tree, and maybe tweak it to perform a different task and then add it back to the community repository under a different name.
Other usages would be creating a foliage system which automatically populates a landscape with objects that are passed into it, or a batch rendering system, parametric model like chairs (google houdini parametric chair or parametric car tutorial).
Basically the system would mean that rather than waiting for one developer to create all this functionality, he would instead just give us the bare essentials to create and share anything we wanted. The system would require minimal upkeep from the devs, because all bug fixes to the existing code would automatically trickle down the the nodes, as they’d be nothing more than visual representations of the existing C/C++ backend functions. Maybe have to add or remove the occasional parameter input from a node.
