Well, this is just a colorful theme for blender newbies, I guess it will be fine for them and also for the instructors because make it easier identify functions with colors and to distinguish editors at first glance, trying to make all more friendly using just the headers, something like the nodes.
The idea behind this theme is make a theme similar to default theme but removing all the contrasts details, text shadows, whites and reduce visual noise and center the attention to only the working elements.
revamped the modo theme from blender for my own use:
#UPDATE: Made some changes in the Scripting Workspace to make it more behave like in Modo(see picture below). Also I did some changes for the Icons in the Outliner to seperate them better.
2#UPDATE: I add for the Material Output in the Shader Node the same color from the shading icon to be more consistent. I also worked on the UV Editor to make the selections consistent from the selection colors. Sadly you can only change the color from the edges in the display settings from the uv/image editor which would be great if you could do this in theme itself. And you can’t hide the facedots which get pretty noisy if you enable it.
3#UPDATE: Fixed the colors for the new setting panel.
It is loosely based on Heavypoly’s config for blender 2.8, which is loosely based on blender 2.79’s “Hexagon” Theme.
It is a rather light theme, with magenta (active) and cyan (selected) highlights. I liked it because i felt like the information design of blender is maintained (it uses most of the color conventions) even though the contrasts aren’t really pronounced. And well, because I find the palette interesting.
Is there any way one could add a 1px shadow/outline to the tool icons to make them go better with brighter accent colors? Right now the only way for me to make it work for yellow for example was to turn down the alpha or darken the actual color, which in the case of yellow makes it look kind of muddy.
If you turn down the alpha for icons in the themes menu it gets better contrast wise but it results in all other icons vanishing.
Not at the moment. It’d be nice to add a feature to draw a shadow behind the icons, just like we can do for text.
For the toolbar icons we can support theming, which would be nice benefit for many of these themes in here.
As for the yellow thing, why not just make the icons display black when selected (on yellow), but bright when unselected (on dark grey). I don’t see your particular issue?
Thanks for the reply! As for making them black on yellow. That’d be ideal but afaik it’s not possible right now to change the toolbar icon color. Are there plans to do so in the future?
i got a question, does the icon color coding affects these themes?. since now they are monochromatic and will be themable ,they all will have to be adjusted later on!!!
Default++
Although it’s a continuation of my version on Default++ from the 2.5 Default Theme, it has become more like a Marmoset theme unintended. Anyways it’s a very distraction free, neutral theme. Opaque menus for the win. The blue and orange accent colors from 2.5 Default Theme but de-saturated a bit with the additional green accent color for Check boxes.
How do I make the toolbar transparent? I have region overlap enabled and some themes have it transparent ,but others don’t. I’m missing a setting somewhere.
Edit:
OK, looks like Region Background alpha under 3D View.
