The local mode issue was solved recently.
Not sure what top themes are.
Awesome, thanks so much! Figures crossed on the rest of it.
Also here is a video that covers many of my same paper cuts, at 13:40 he runs into the same camera issue.https://www.youtube.com/watch?v=IJ3YFK2uBa0&t=271s
Hey, I like your idea except the double click part. Using double click to change the value would slow the workflow down.
I’d like to suggest:
- Let the single click as is (single click for inserting the value)
- Instead you could replace the single click to ctrl + single click for changing the value as the cursor position.
- And/or ctrl + mousewheel for changing the value as the mousewheel scrolls.
- IMHO, it’s more convenient and wouldn’t slow down the workflow, instead it will speed it up.
PS: ctrl could be replaced by shift or alt; I think ctrl is more relevant and natural though.
EDIT:
Forget about my suggestions above.
After some thought, I agree with you and double click wouldn’t slow down the workflow.
Double Сlick, LOL.
When I enter a value (from the keyboard) and then click into another field, it only confirms the current input and I have to click again to enter. It’s already two clicks, slow and annoying. Triple click? No, thanks.
And let’s agree that these are two types of input fields:
they are the same and both work the same way. Just one of them has an extra visualization, but it’s not a slider, it’s an input field.
@jenkm We developed the subject a little more. Your contributions and suggestions are welcome here.
Link
The one below is a value slider, it has a hard maximum, so it displays the current value relative to the maximum (in this case 1), the one on top is a number field which allows for any number, hence a percentage of maximum -infinity- cannot be displayed, as there’s no such thing.
That approach has several drawbacks:
- mis-clicks become a whole lot larger of a problem.
- Imprecise. the larger the value difference between min and max, the less less likely you are to hit the value you’re after. And if it requires tweaking after clicking (by dragging), you mayaswell have click+dragged.
- Imprecise again. If the dragging behaviour only uses the space of the slider, then now you have no way of setting values without bouncing over and under the value you want (worse the higher the mouse sensitivity is, or the smaller the panel is).
- not all value sliders have bounded ends, being able to adjust whist above or below the bounds would be a pain in the ass.
- It’ll change the value to some arbitrary mouse position if you try and click+drag over multiple fields to edit them in sync.
- It’s inconsistent with the other value field types.
The current click-to-edit, drag for fast edit, shift+drag for slow edit handles all situations quickly and effectively. It’s also consistent with all of the other value field types.
Why are you even talking about something that clearly you have no experience with.
Damn, this is a joke really.
man, you’re just trying to force yourself to find faults that are actually distortions of evidence that this change has 100% advantages …to say:
“I do not want to change my mind, I’m lazy to unlearn and relearn”
Quit the (baseless) Ad-Hominem
I’m not lazy, I would have nothing to unlearn or relearn, because I use those types of sliders in other programs all the time. I’m using some right now.
And they suck.
If I’m changing a value, I either know the value I want, or I’m looking at feedback from the program to find the value I want.
In the first instance, with these kinds of sliders, you never land on the value you want, meaning you have to drag around anyway.
Even then, when you reach near the number you want, most of the time the increment it’s ticking up and down by will leave it at something like 50.21 or so when you’re trying to get 50 (assuming all the factors even get it that close, like the mouse sensitivity, or your ability to move the mouse by a tiny fraction, whilst holding a mouse button down, I might add!).
But then you go to enter in a numerical value and find it’s a pain in the ass to change the value numerically anyway, because you have to double click - meaning the program is going to change the value, causing a possibly time intensive update, before even letting you change the value to the actual value you want. Or maybe you’re lucky and the program left a 3 pixel wide space where the ‘I’ cursor pops up and you can single click to edit the number, assuming you don’t miss it.
The only other use for these sliders is moving along them during realtime updates to watch the feedback and find the right value. Which the click+drag functionality is perfect for already. Or, trying to get ballpark values for something when you don’t have immediate feedback because things are laggy or something else delays the feedback like rendering. In this last instance, it’s slightly faster, but that’s one out of three use cases for the slider, and a use case where things are assumed to not be happening fast (you’ll be waiting for feedback) anyway.
at present … you never used shift + drag
or ctrl + drag to set more precise parameters?
it would be the same identical thing for the other method …
trust me…
the current method is slow which makes me sleep …
and I’ve been using blender for 20 years
and I recognize that it is slow,
It is a fact that anyone can check in 2 minutes.
The items on this list are inverted now?
It used to be the other way around.
I absolutely love this thread. Papercuts really are deadly in large number, with enough of them you can bleed to death. This thread is full of so many great little things that could be improved in Blender (some of which have already been fixed which is great). Little changes like these make a huge difference in total.
All menus open either towards the top or bottom depending on the available room (which explains that this particular dropdown changed recently because 3DView header was moved to top by default), and their items are ordered from “start to end”, ie from button to wherever the dropdown is expanded, in this case towards the bottom. I’m personally not a fan of arranging things this way, as I tend to remember direction over ordination (pie menus!), and I would prefer dropdown items be fixed, whether or not they open towards the top or bottom.
not sure whether this is a papercut a pure bug but here’s the issue:
when an object is linked to only one collection, unlinking it from its collection using the properties panel makes it become orphan data, which make it disappear from the scene and the outliner and remain unusable. wouldn’t it make more sense to link it to the default scene collection?
When you work on nodes and you scale out its very difficult to grab the input/output points.
In fusion 9 they make it that the scale of the node points are scale with the view scale.
I miss also that the grab radius is greater than the point icon. (red radius in the pic)
that make the entire workflow much faster.
