Hey!
Every time, i try to render a picture with cycles and gpu, blender just closes after a few seconds while it says (loading render kernel, compiling kernel)
Does the blenderteam know that issue? Is it trying to fix that?
Here are my specs:
CPU: ryzen 7 3700x
GPU: RX 5700xt 8GB
RAM: 16GB 3200MHz
PSU: 500W (Seasonic)
Hi same here.
All versions of 2.8 / 2.9 Blender broken with current AMD drivers.
The only AMD driver that works is the February 2020 Enterprise driver.
Cheers
Create a report, Help > Report a Bug, with all the details, driver versions and so on.
This is not the right place for such questions or bug reports.
The bug is an AMD driver issue … which they are aware of.
As an open query, this is the correct place to sound out a problem and serves as a signpost for all others with the same issue, with a noted workaround (feb enterprise drivers). Finding info on this issue is quite difficult - so why not have it aired on open forum.
for anyone with a setup similar to the one in this thread, try reverting the video drivers to the version 20.4.2.
