Hi. not sure if this is the best place to post Beta bugs!
I am using the latest build as of this post, the 2.81 build: blender-2.81-0a0d735acd6e-windows64.
Issue: sculting brush property “Original Normal” is not behaving the same way as the release version. Seems like the property is not being set on checking the check box.
Thank you
Original Normal option is no more supposed to work as in 2.80.
The option was intentionally split into two option Original Normal and Original Plane.
https://developer.blender.org/D5818
If you enable both options, you should obtain a similar result that unique option in 2.80.
It looks like this mention is absent of 2.81 release notes.
Excellent that works for me, thank you
