Auto merge, split edge and ¿faces?
I have been testing this feature and im not sure if it is a paper cut simple issue that the description isnt clear enough or if it is something buggi
imagen
The edge split part works perfect, snaping vertices/edges or simply overlaping edges, but the split face its not doing it. . . is it a bug or a misunderstanding?
Same model with triangulate modifier turn off
