No problem. I can add that
any update from this?
Not yet. Next steps are to finalize and publish the existing realistic and stylized assets on blender.org.
But they can already be downloaded from the repository (link in the thread description).
Sorry the thread was accidentally archived. Itās now open for replies again
The realistic and stylized assets are now all cleaned up and basicaly ready to be released.
You can already download the bundle in main description and install it with the included instructions.
Thanks again to @dan2 @1D_Inc @Tonatiuh for the fantastic contributions!
Awesome!!! Iām still planning in doing the other ones that I have not finish. Can they go in 4.0?
Looks very cool! Thanks for all your efforts to make this happen Julien.
They all look amazing! I really enjoyed seeing the refinement process on such high quality topology.
I wanted to pitch in, but only with a proposal to flip the name order, into āHead Realistic (Sculpt)ā and āHead Stylizedā. This would lead to much nicer default grouping, given alphabetical is always the default. Since the assets are already have tagged subcategories for stylized/realistic, the toggle for only seeing stylized assets is still right there.
For this specific bundle Iād agree that either order of naming is fine, but since this one bundle would set the precedent for future bundles Iād thought this point should be raised now? Because the naming rule for āThing+Type+Variationā becomes, Iād argue, much more definitively the nicer way to go when organizing rock assets (Rock Sandstone Big 1), or brush assets.
Itās a naming style Iāve personally always used in different teams, this suggested style guide (for in this case Unreal) fleshed out the ideas:
BaseAssetName
should be determined by a short and easily recognizable name related to the context of this group of assets. For example, if you had a character named Bob, all of Bobās assets would have theBaseAssetName
ofBob
For unique and specific variations of assets,
Variant
is either a short and easily recognizable name that represents logical grouping of assets that are a subset of an assetās base name. For example, if Bob had multiple skins these skins should still useBob
as theBaseAssetName
but include a recognizableVariant
. An āEvilā skin would be referred to asBob_Evil
and a āRetroā skin would be referred to asBob_Retro
Depending on how your asset variants are made, you can chain together variant names. For example, if you are creating flooring assets for an Arch Viz project you should use the base name
Flooring
with chained variants such asFlooring_Marble_01
,Flooring_Maple_01
,Flooring_Tile_Squares_01
THatās a great suggestion! Iāll also go over the naming with other devs
It will make much more sense to ahve them sorted by type instead of catalog.
Luckily the asset bundle is not tied to Blender releases anymore. Weāll release this one around the same time as Blender 3.6 to highlight it in the release notes page, but any future update can be done any time.
Iāll also add more assets to the bundle once I have time. Feel free to pick up anything from the list or suggest additions
Hi! I was looking to download the bundle but the link seems to be broken, I assume it has something to do with the svn=>git migration.
Actually it was because bundles got moved to another folder. I updated the link
The asset bundle version 1.0 is now availible on the demo files section of blender.org!
Hi, amazing work on this asset bundle! Didnāt know about this going on until I saw it on the Blender 3.6 release post and wanted to try it immediately.
Not sure if this is the right place, but it seems that āSkull - Realisticā is not subdivided? I only see a low-res version.
I downloaded the asset bundle and imported the model as by this video: Base Meshes - Free Asset Bundle - YouTube
When I drop-in the skull, it comes with the Multires modifier, but changing the āLevel Viewportā between 0-3 doesnāt seem to do anything.
The āBody Female - Realisticā also has this Multires modifier. However, for this model it works fine.
My system:
- Blender 3.6
- Linux (Ubuntu 20.04)
The skull model:
- Vertices: 11,684
- Edges: 23,268
- Faces: 11,634
- Triangles: 23,268
Am I doing something wrong here? Let me know if you need more info.
It seems like the Multires modifier is disabled. I can fix that once the bundle gets updated again.
Hi there, I think Iāve spotted something in the base meshes, when using subdivision higher than 4, there are some lines that appears when using Geometry>Pointiness, here is a screenshot.
Iām using Blender 3.6 and the latest update of the basemesh bundle.
The ālinesā appear on the animation/sculpt head mesh and female full body, didnāt test with the others.
If anybody else experiencing the same thing (bake some textures using pointiness), the workaround is to scale up the mesh. at 3+ meters, the lines seems to disapear.
Why would you ever use subdivision levels higher than four?
That has to do with the pointi function and nothing with the mesh. Its somewhat inaccurate and i had this problem countless times⦠Solved by scaling and applying the mesh but that messes up sss and its a so called vicious circleā¦
Anyhow i subdivide my meshes for sculpting to 6 and thats a pretty nice resolution for skin detailsā¦
My guess is the higher subdivision leads to zero-sized quads (due to float precision) at the default scale, which confuse the pointiness function.
