These are a list of things that I think could greatly benefit user experience for animation purposes, they’re in no particular order, but just things that I’ve been having trouble with before in 2.79, and some that just appeared in 2.8.
Timeline / Dopesheet / Grease Pencil… :
As of now we actually have 7 different “modes” under the dopesheet
…but none of these can see all the keyframes at the same time, something that makes handling all the keyframes on the scene a headache, at least one of these modes (dopesheet probably) should be able to be used to display and move all the keyframes at the same time.
Auto Keyframe:
Auto Keyframe should only keyframe attributes / properties that have been keyed by hand already:
Example: I have a cube that has no keyframes, and I have auto keyframe on, it shouldn’t add keyframes on it no matter how much i move it, that way we avoid having keyframes on everything which is a common problem. Only after I manually hit I or add a keyframe through an attribute that and only that property will key further keyframes automatically.
Snapping:
Snap the frame indicator to the keys and or markers when you drag it by holding control, kind of like what happens when you drag the frame indicator in the VSE by hitting ctrl…
And same thing vice versa if im moving a keyframe hitting ctrl should allow it to snap to the frame indicator and the markers.
*Should work in the graph editor, dope sheet and every timeline type of editor.
Mute Keys:
Ability to "MUTE" keyframes making them be skipped from evaluation / interpolation… (like when you mute a node in the node editor.)
Channel Filtering:
- When you select a channel isolate it (turn the rest off) and frame it.
- There isn’t a quick way to also do this for several selected objects, example I have 10 objects and I only want to see the Y translate of all of them, the closest now is to use the magnifier glass and write “x eul…”
Channel Pinning:
Pinning independent Channels not only the whole group and also channel pinning should work in the dope sheet as it does in the graph editor.
Value Input:
Be able to input or have the active keyframe input work for several keyframes at the same time instead of just the active one.
Curve Modifiers:
As with value input it would be incredibly nice that modifiers would get modified together if multiple channels containing modifiers with the same name are selected.
This would also be a lifesaver if it were true for driver’s modifiers and drivers variables.
Smart next / previous keyframe:
When using next and previous keyframe jump only on the keys of the selected channel, curve, and if no key is selected jump between keyframes of all of the selected object / objects / armature / bones.
“Filters” option:
Currently there is a big button “filters” in the graph editors header, though its pretty unuseful and misleading for the most part because it filters keyframes from object data and not object types: so the expected behaviour is that if I uncheck the bulb button, it will not show me the keys related to my moving lamps, though it does because that’s transform data, so even if I do not disagree that all of these options exist, I think it would be great to have filtering of animation by object type and it would make much more sense, so for instance you could show only geo keyframes (no matter if the keyframe are in its materials, or textures or modifiers, etc.)
Snap Keys Menu (Shift S):
Flatten handles: to me doesn’t really fit here, and it’s the only actually very useful option, maybe it should find it space under the V.
The menu is missing “cursor from selection”, “snap to cursor y” and “snap to cursor x” from the view properties in the n panel, and we could get rid of that entire tab… options that completely make sense to have in this hotkey as you’d find also in the 3d Viewport,
Other Channel things :
Problem: When you set a key in location vía “ I ”, you get in the channels a “group” named “rotation” under which the rotation channels are grouped, but then if you go and set a key by hovering on the translation channels (in the transform panel under the n) and hitting “I” you get the translations with no such group, all this leads to confusion and disorganization in the graph editor and dopesheet.
Possible solution: Should it just create the transforms under the actions with no grouping, unless you manually group channels?.
“make cyclic / clear cyclic”
Problem:
- You have the option to do this in the dopesheet (same hotkeys as in graph editor, shift E), but it doesnt work, it does nothing… this is probably just a bug but it’s been there forever.
- Very many times you make cyclic a lot of channels at the same time, but if you want to make any changes then you have to go copy and paste one by one the modifier to each channel you want to affect.
Possible solution to number 2:
Be able to modify curve modifiers on several curves at the same time.
Keyframe adding.
Problem: when you add a keyframe it changes the shape of the curve in some cases as portrayed in the following images:
A: + B:
Result:
Breakdowner for Objects… Self Explanatory (?)
Breakdowner for graph editor that can create new keys and or breakdown and handle the selected keys.
Like this:
Timeline:
the timeline in blender "only" supports up to 1048574 frames, but the space for the frames in the start, end and current frame is there all the time yet nobody ever goes above 4 digits in real life (i mean for the most part), so maybe the start, end and current frame number could be shrunk to the 4 or 5 digit mark and if the number gets bigger than that grow it that way we’ll take waaay less space in the header.
Graph Editor:
Some tidy up could be done to free space in the header and put stuff in a more logical way:
I stole this screenshot from this proposal, out if it all i think is the only part that is still relevant from it.
Waveform:
Have waveform drawing in the timeline / dopesheet
It would be nice to be able to either have a mixdown of all the audio in the vse to display the waveforms in the dopesheet and or timeline for when doing character dialogue or hand animation to the rhythm of the music, if this was achieved then the process would be much less of a hassle.
Just as a side note:
Here is Alan Camilo’s animbot tools a set of tools for maya that I currently use, and I can say that i don’t use it on a daily basis I use it on a minute by minute basis, it makes the process a lot faster, but definitely many of these could be implemented as an addon since are really animator focused… check it out.
Tools from animbot/atools I’d like to see in blender:
animBot -
animBot -
animBot -
animBot -
animBot -
animBot -
animBot -
animBot - for the breakdowner which is similar to the tweener
animBot -
animBot -
animBot -
