9 August 2021
Modules & Projects
Rendering:
Geometry Nodes:
  • Jacques Lucke will be in Amsterdam this week for another geometry-nodes workshop.
  • The main goal is to move on with the attributes proposals.
  • Current prototypes:
New Features and Changes
USD
  • Add USD importer (commit) (Michael Kowalski)
Asset Browser
  • Use the active material slot when dropping a material on an object (commit) (Jeroen Bakker)
    • Add tooltip for material drag and drop (commit) (Jeroen Bakker)
  • User interface improvements
    • Proper context menu for assets (commit) (Julian Eisel)
    • Header adjustments to be specific to the asset browser (rather than the file browser) (commit, commit) (Julian Eisel)
Grease Pencil
  • Brush option to define Caps type (commit, commit) (Antonio Vazquez, Matias Mendiola)
  • Select Random operator (commit) (Antonio Vazquez)
  • Add Merge Layer to the default keymap: Shift+Ctrl+M (commit) (Antonio Vazquez)
Geometry Nodes
  • Select by Handle Type Node (commit) (Hans Goudey)
  • Curve Set Spline Type (commit) (Johnny Matthews)
  • Add more warnings for out of bounds parameters (commit) (Eitan)
Rigging
  • Action Constraint: Add Split Channels Mix choices from Copy Transforms (commit) (Alexander Gavrilov)
Cycles
  • More flexible GI Approximation AO distance control (commit) (Sergey Sharybin)
  • Make object Fast GI Approximation panel a subpanel of Shading (commit) (Brecht Van Lommel)
  • Move Cycles visibility, holdout and shadow catcher properties to Blender (commit) (Brecht Van Lommel)
User Inferface
  • Improve the font display name for text objects (commit) (Harley Acheson)
  • Add the option to draw viewport normals with a constant length (commit) (Piotr Makal)
  • Add light count to viewport statistics (commit) (Falk David)
  • Make loop-cut tool drawing consistent between the active tool gizmo and the operator (commit) (Anthony Edlin)
Mesh Editing
  • Support N-gons in the laplacian smooth edit mode operation (commit) (Campbell Barton)
  • Improve performance by Tag normals dirty instead of calculating (commit) (Hans Goudey)
VR Support
  • Action map support for XR controller input (commit) (Peter Kim)
Video Sequence Editor
  • Allow Wingdings and Symbol Fonts (commit) (Harley Acheson)
Python API
  • Library Overrides
    • Add removal of properties and operations to RNA API (commit) (Bastien Montagne)
    • Add RNA API to reset / delete overrides (commit) (Bastien Montagne)
    • Add python API function to update override operations (commit) (Jeroen Bakker)
  • Expose Color Management as argument for gpu.types.GPUOffScreen.draw_view3d() (commit) (Gottfried Hofmann)
Weekly Reports
