4 December 2023
Announcements
Modules & Projects
- 2023-11-28 Nodes & Physics Module Meeting
- 2023-11-30 Pipeline, Assets & I/O meeting
- 2023-11-30 Animation & Rigging module meeting
New Features and Changes
Anim
- Change how Only Insert Needed works (commit) - (Christoph Lendenfeld)
- Add “Add/delete” track operations to NLA context menu (commit) - (Nate Rupsis)
- Refactoring NLA menu into more sensible format (commit) - (Nate Rupsis)
BLF
- Support All Render and Bitmap Formats (commit) - (Harley Acheson)
- Fix Shader Type Conversion (commit) - (Harley Acheson)
- Rename Text Shader Depth to Component Len (commit) - (Harley Acheson)
Color management
- Multi-thread IMB_colormanagement_transform_from_byte_threaded simple case (commit) - (Aras Pranckevicius)
Compositor
- Better node visibility for default node tree (commit) - (Habib Gahbiche)
- Make split viewer a regular split node (commit) - (Habib Gahbiche)
- Disable preview of Split node by default (commit) - (Omar Emara)
EEVEE-Next
- Optimize GBuffer Layout and writting (commit) - (Clément Foucault)
GHOST/Wayland
- Improve tablet event handling (commit) - (Campbell Barton)
- Animated cursor support (commit) - (Campbell Barton)
GPv3
- Lock unselect materials operator (commit) - (Antonio Vazquez)
- “Set Active Layer” operator and menu (commit) - (Clément Busschaert)
- Duplicate Points operator (commit) - (casey bianco-davis)
- Show and hide layers operators (commit) - (Matias Mendiola)
- Menu to Select Material using
U
key (commit) - (Antonio Vazquez)
Geometry Nodes
- Rewrite parts of extrude mesh node (commit) - (Hans Goudey)
- Remove drag & drop requirement of geometry input (commit) - (Hans Goudey)
- Remove experimental volume nodes (commit) - (Lukas Tönne)
Multires
- Use IndexMask for Subdiv CCG face updates (commit) - (Hans Goudey)
OBJ
- Add import option to create collection hierarchy by splitting names with a separator (commit) - (Aras Pranckevicius)
Realtime Compositor
- Implement zero cost external images (commit) - (Omar Emara)
- Add utilities to handle texture formats (commit) - (Omar Emara)
Text Editor
- Use active text selection as search query (commit) - (Guillermo Venegas)
UI
- Improve description of custom asset library type (commit) - (Julian Eisel)
- Enable immediate typing for 'Select Pattern" operator (commit) - (Philipp Oeser)
- Icons for Area Join and Swap (commit) - (Harley Acheson)
USD
- Improved texture coordinate translation (UsdTransform2d) (commit) - (Charles Wardlaw)
VSE
- Speedup timeline drawing, and improve waveform display (commit) - (Aras Pranckevicius)
- Speedup Luma Waveform display output mode (commit) - (Aras Pranckevicius)
- Speedup “show overexposed” option (commit) - (Aras Pranckevicius)
