2024-11-07 Animation & Rigging module meeting
The meeting will be on 2024-11-07T17:00:00Z. It is open for everybody interested to join the video call (link below).
Present: Christoph Lendenfeld, David Woolf, Dimitri Gouacide, Drew Medina, Jorn Boven, Nacho de Andrés, Nate Rupsis, Nathan Vegdahl, Nika Kutsniashvili, Raymond Luc, Swann Martinez, Sybren Stüvel
Links
Opening
  • Please raise your hand when you don’t understand things for any reason. The purpose of these meetings is collaboration. It is absolutely fine to ask for explanations.
  • There are no recordings of the meeting. This way everybody is free to say or show anything they want.
Landed
Names are from the Git log. This list is limited to functional improvements & bugfixes.
Blender
Technical Documentation
Ongoing Work
  • High Prio bugs:
  • Christoph:
  • Nathan:
  • Sybren:
    • Sybren’s weekly report
    • Interesting report: #129587: NLA modifiers not interacting with each other properly
      • We should take this into account when designing layered Actions. Where do we keep track of such things?
      • Christoph: add an NLA category to the ‘Weak Areas of the Animation System’ page, and link it there.
    • Feedback/confusion Tal Hershkovitch: #129563: An extra Action slot created called “Slot”
      • Sybren: name the slot “Shared Slot” when the Action was shared? Lots of nodding heads.
    • Moved the longer-term vision document to technical docs (might need a while for the buildbot to publish, the updated text says Slotted Actions will be in 4.4).
    • #129376: Anim: Dope Sheet, Select by Key Type
      • What if there are keys selected, but none of the chosen type?
      • Nathan: feels like a bug.
      • NDA: could report a warning about this, and then not deselect everything.
      • Nika: always report the number of keys selected. NDA likes the idea.
      • Nathan: having this ‘selecting’ and ‘filtering’ in the same option feels a bit weird. Maybe these should be two operators?
      • NDA: maybe a dynamic label in the menu, depending on selection state? Sybren: impossibru, as finding “is anything selected” requires looping over all F-Curves, all keys. Maybe in future an improvement to the F-Curve could be keeping track of the nr. of selected keys.
      • Nathan: also only helps if they use the menu, as the hotkey may still behave unexpectedly.
      • NDA: Maybe “select / filter by type”? Double functionality is better than double operators, as it makes it possible to share hotkeys.
      • Nathan: ‘select all objects’ would work with A hotkey, where pressing once would ‘select all’, and pressing it again would ‘deselect all’.
      • Nathan: maybe the filter is the important one to have (people nod), and then you can always do ‘A’ + ‘filter by type’.
      • Nika: could we have ‘selection state’? So have SELECT, DESELECT, TOGGLE in there?
      • NDA: maybe have these as buttons in a panel in the N-sidebar, and then plain/shift/alt click to do the differen types of selection? Christoph & Nathan like the idea.
      • Sybren: not sure if the UI guidelines allow for such buttons.
      • Raymond: Feature Request: can we have a new keyframe type “inbetween”? Sybren: technically easy to do, but hard to come up with a visual way to identify them.
      • Jorn: suggests a mode that expands the selection of keys of the given type, by expanding the selection until keys of other types are seen. Bit like “select islands” in UV editor.
  • Animator meeting at Blender HQ, with Rik Schutte and Pablo Fournier:
    • Sybren showed #129376: WIP: Anim: Dope Sheet, Select by Key Type, got approval from Rik & Pablo.
    • Rik’s Request 1: ‘Copy to Selected’ on shapekey properties, for example to set the minimum value to -1 on all selected shapekeys.
      • Christoph nods
      • Nika: Every UI list should get replaced by the tree view, which has multi-selection. This will help a lot here.
      • Nika: Interested in adding this to his Bake Shapekeys add-on.
    • Rik’s Request 2: Rotation Mode Polish.
Demo by Swann
Exploiting Pose Library and VSE: a case study by Cube Creative
For reference: Sybren’s work in progress on animation snippet support in the pose library, via drag & drop: #129381: WIP: Anim: Add drag & drop of Actions to the asset browser
Next Meeting
The next meeting will be on Thursday 2024-11-14T17:00:00Z. Again it will be open for everybody who’s interested. The provisionary meeting agenda will be updated before the meeting.
