User Interface Module Meeting
Regular User Interface module meeting for planning and coordination. Last meeting was December 5, next meeting on January 16.
Attendee
- Harley Acheson
Merged Since Last Meeting
- Fix #100784: Truncate Text with Ellipsis inside Number Inputs #115958
- Fix #114838: Force Full Redraw When Duplicating Areas #115959
- Fix #115938: BLF Handle Negative Left-Side Bearings #115965
- Fix #116135: Ensure blf_font_width_to_rstrlen always works #116208
- Fix #40009: Win32 Use Message Time for Events not Current Time #115872
- Fix #116137: Overflow causing event time false positive warnings #116164
- Fix eyedropper outside blender on mac #115187
- Fix #116196: Edge selection with hidden Asset Shelf #116233
- UI: Set Initial Background Color Darker #115968
- UI: Show “No results found” for empty searches #116201
- Fix #116415: Show Empty text for Current Asset Library #116446
- Fix #116558: Console error due to missing property use_template_override #116559
- IO: Add support for multiple drag-n-drop files #107230
- Fix #116252: Corrections to Text Object Special Characters Menu #116677
Awaiting Approval
- UI: Dynamic File Browser Tooltips #104547
- UI: Improved Operator Confirmations #104670
- UI: Cleanup Dialog to Manage Orphaned Data #106653
Design
- Translated Interface when enable Tooltips #76101
- We need to decide if translating “Tooltips” is just that
Quick Reviews
- UI: View As Render for Background Images #115120
- UI: Implement a Clear Recent Files List Operator #116494
Discussion
- Outliner: Double-click on item icon to select contents/hierarchy #110151
- Harley could update to address most (but not all) review feedback?
- UI: Unit completion hint when text editing #116103
- Appears to be WIP, but could be a great improvement
- UI: Gizmo Button for Lock Camera to View #111076
- Approved by Harley & Campbell, then reverted. What is needed to reconsider?
- UI: Consistent Use of Chevron Disclosure Icons #116240
- Might need to consider usage rules for these icons
Demos and Experiments
- UI: Blinking Text Cursors #116595
- UI: Experiment - Editor Edge Highlighting #116684
- WIP: Unicode Character Text Entry #116679
- WIP: Demonstration of Edit Mode Cursor Preference #116645
- WIP: UI: Save Temp Window Sizes & Positions #104727
- UI: File Browser System Root View #111714
- Would love this as an official target. Would require some assistance from Julian
