The meeting will be on 2024-09-26T16:00:00Z. It is open for everybody interested to join the video call (link below).
Present: Christoph Lendenfeld, David W, Luciano Muñoz, MohammadHossein Jamshidi, Nate Rupsis, Nathan Vegdahl, Sybren Stüvel
Links
- Video Call. Note that there are no recordings of the meeting. This way everybody is free to say or show anything.
- A&R Module Meetings calendar for inclusion in your own calendar
- Previous meeting notes
- Issues & Pull Requests
- #module-animation chat channel
- Draft agenda for any upcoming meetings
- Last week of development work on the Slotted Actions project.
- Wednesday Blender 4.3 will go to beta phase, which means that the
main
branch will be 4.4-alpha. - After that we can remove the experimental flag for Slotted Actions.
- This means that in 4.4-alpha, all Actions will be automatically versioned to Slotted Actions!
- For clarity: Layered Actions and Slotted Actions are the exact same thing, just focusing on different aspects of the new-style Actions. The slots are there to support layered animation, and the data structure for layers & strips is already in place. Blender 4.4 will have the slots exposed to the UI, but neither layers nor strips.
- Christoph & Nathan will handle the fallout of the switchover.
- Starting next week, Sybren’s coding time will go to the Online Asset Repositories project.
- Sybren will still be project lead for Slotted Actions.
Landed
Names are from the Git log. This list is limited to functional improvements & bugfixes.
Blender
- 2ba69519a8b: Fix #127678: Auto-Save Preferences does not work for few anim properties (Pratik Borhade)
- b58f61a91ad: Fix: inconsistent bone selection after hiding or changing selectability (Philipp Oeser)
- 12fe0dd0cf9: Anim: make action/slot assignment code more generic (Sybren A. Stüvel)
- 4b642637b9f: UI: fix nullptr access in slider drawing code (Sybren A. Stüvel)
- e0d5379ef8d: Anim: change how action strip data is stored (Nathan Vegdahl)
- 38e15412dd8: Fix #127755: 4.3 regression: Some rigged meshes do not load properly (Sybren A. Stüvel)
- 02d0c258d91: Anim: define RNA subtypes of ActionStrip, and refine to those types (Nathan Vegdahl)
- 6ebe7a39850: Anim: don’t evaluate the Action constraint if it has no Action (Sybren A. Stüvel)
- fe681909231: Anim: fix group name check in Action constraint (Sybren A. Stüvel)
- 615cb464128: Anim: add Action Slot selector to Action Constraint (Sybren A. Stüvel)
- b200d1f9754: Anim: remove strip data as well when an action strip is removed (Nathan Vegdahl)
- 26379c2b014: Anim: Update Action Slot selectors in the UI (Sybren A. Stüvel)
- 34a18c7608b: Anim: Merge Animation operator (Christoph Lendenfeld)
- ee2d8ec8dbb: Anim: add slotted Action support to
animdata_copy_id_action
(Sybren A. Stüvel) - cd1c7039ac9: Anim: correctly assign Action in
id_action_ensure()
(Sybren A. Stüvel) - 6115132998d: Anim: migrate Action assignments to the new API (Sybren A. Stüvel)
- 4bfa0de388c: Anim: update some uses of listbases of fcurves (Nathan Vegdahl)
- 6d8e3959b07: Anim: Fix legacy/layered choice in action_fcurve_ensure() (Sybren A. Stüvel)
- 22868682988: Anim: support layered Actions when symmetrizing Action Constraint (Sybren A. Stüvel)
- 6ea0b8cdb20: Fix #127758: Resorting keys in the Graph Editor with multiple actions failed (Christoph Lendenfeld)
- 0c9ef75df85: Fix #127976: Actions created via Python can’t be used in action constraints (Sybren A. Stüvel)
- 3b878592041: Anim: Convert Grease Pencil conversion code to new Action API (Sybren A. Stüvel)
- 629b3ccd422: Anim: update collada export code for slotted actions (Nathan Vegdahl)
- 5524a060384: Anim: support layered Actions in BKE get/set active actiongroup functions (Sybren A. Stüvel)
- 4159f60e46e: Anim: Layered Action support in group handling in action_mirror.cc (Sybren A. Stüvel)
- 02ebab57da1: Anim: add layered Action support to BKE_animdata_transfer_by_basepath (Sybren A. Stüvel)
- fae19d7c927: Anim: Eyedropper for bone properties (Christoph Lendenfeld)
- 9eae533e899: Fix #127908: Layered Action - slot users doesn’t include action constraint (Sybren A. Stüvel)
- 45085b2b0e1: Fix: cannot assign actions to IDs without animdata (Nathan Vegdahl)
- 124bae5a4d5: Fix: use
action_treat_as_legacy()
where appropriate (Nathan Vegdahl) - 147d8aad54a: Anim: Show Action Slot type in panel + change type icon RNA prop (Sybren A. Stüvel)
- bcd0d14943d: Versioning for layered actions (Christoph Lendenfeld)
Technical Documentation
- 48903d8f: Anim: move ‘project Baklava’ to ‘Layered Animation’ + better explanation (Sybren A. Stüvel)
User Manual
Ongoing Work
- High Prio bugs:
- Christoph:
- Christoph’s weekly report
- #128171: Anim: operator to move Slots to new action
- started work on an operator to “explode” an action
- Nathan:
- Nathan’s weekly report
- Helping update code that directly loops over fcurve listbase to also support slotted actions.
- In theory will be working on updating pose library code for slotted actions as well, but…
- In practice I’ve gotten pulled into fixing a variety of bugs.
- Sybren:
- Sybren’s weekly report
- Julian Eisel made this for our slot selectors: #127751: UI: Allow label for search template (respecting property split layout)
- #127904: Anim UI: Labels for Action/Slot selectors or not, in the Properties Editor?
- Nathan: in favour of labels. Let’s make it a rule that vertical placement means having labels.
- Christoph: labels take space away from the Action/Slot names. I know it’s an Action. The icon also shows. Sybren: yeah, this is why I initially didn’t put the labels there.
- Sybren: in 4.4 people won’t know the icon for Action Slots yet.
- Nathan: in the properties editor, all properties (in similar sections) have those labels. So without labels it looks a bit inconsistent. Also agrees with Christoph’s points.
- Bastien Montagne has PR for various issues with the Action’s
idtype
property (#128129). Most notably, we have to be careful when reading/writing suchidtype
properties, and have to adjust this in the Slots read/write code.
Patches: Review & Decision Time
- #124412: UI: Frame Specific Axes
- Module: agrees this is good idea.
- #127826: Link Animation Data does not update self-referencing drivers
- Sybren: fix this by detecting self-targeting drivers, and modifying them on the copy? Or add another driver value that says “Current Object”, which will remain valid?
- Nathan: in favour of the latter, as it is more explicit and will keep workflows working that depend on the current behaviour.
- Module agrees the latter is the better solution.
Blender Conference
We need to prepare a presentation for Blender Conference.
Sybren will set up git repository for revealjs presentation, and start a HackMD document for the first drafts of the presentation.
Next Meeting
The next meeting will be on Thursday 2024-10-03T16:00:00Z. Again it will be open for everybody who’s interested. The provisionary meeting agenda will be updated before the meeting.
