Attendees
- Bastien Montagne
- Campbell Barton
- Dalai Felinto
- Francesco Siddi
- Philipp Oeser
- Sergey Sharybin
- Thomas Dinges
Notes
- Policy for the enumerator values
- The technical feedback thread: Style for enumerator values
- Generally fine to follow TitleCase for enum class, as it what most of the active developers prefer
- Avoid big cleanup, if possible
- The admins share a concern of abbreviations in the names (
ID
,UV
,BSDF
,IOR
, etc). A guide for those needs to come together with the new enumerator value guide.
- A topic of using literal
and
andor
in C/C++ code was brought up.- The consensus is: don’t use them.
- The style guide needs to be updated for that
- The meeting discussed renaming BCON levels to matched release cycle names
- The goal is to make things more clear for people who are more occasional to the community, or new to it.
- The downside is that it looses the strict moment in the release schedule where big changes are not allowed, but smaller are fine.
- It was always fuzzy tough, and was checked on case-by-case basis
- It is possible to have clear rule like “projects should land within N weeks of alpha” (just an example)
- Need to check with Ton and gather feedback from other active members of the community
- Once everybody is on-board, Thomas will help with communication and updates
- World texture nodes
- They are in some weird limbo, where you can select World texture in the Texture Nodes editors, but can not add them
- Agreement is to remove for 4.3
- 3.3 LTS is technically overlapping with the 4.2 LTS for August and September. We accept this overlap, but might not be as pro-active in backports (only port really crucial fixes). In the future such overlaps should not happen, as all the releases will be made with the same release schedule.
