Attendees:
- Campbell Barton
- Dalai Felinto
Recent changes
Updates since the previous meeting:
- Improve UI for adding/removing repositories.
- Update manifest to bl_info conversion.
- Support addon_utils.module_bl_info() for enabled extensions.
- Detect time-stamp changes to extensions manifest on refresh.
- Using SPDX for licenses.
- Manifest updates.
Server-specific changes:
- Remove support level for add-ons, as well as documentation URL.
- Pass the official (extensions) website as the individual extensions on the JSON.
- The manifest website is still used to populate the extension page, but not passed to the JSON.
- Make website and tracker url as optional
- Get schema_version, tagline and other fields from manifest
Manifest changes:
- author → maintaner (single string)
- homepage/tracker/documentation_url → website
General Topics:
- Aim at smaller more granular tasks.
- For now closing the main UI task, and creating individual tasks for the remaining parts.
- Dalai started working on the user documentation.
Repositories
- The pop-up is fine as it is.
- It would be nice if we could have a directory button for custom folders
(crashes at the moment). - Still misses a tooltip for the Custom Folder option.
- Should check for updates after created.
- From the UI is not possible to turn a remote repository into a local one (and vice-versa).
- The “Use Remote URL” checkbox should only be accessible via the API.
- Talked about renaming Remote/Local to Online/Offline (or Online/Local), but nothing conclusive.
User Interface
- Error/warnings
- Stick to the current solution (make it dismissible though).
- Inquiry the UI team to get their green light or a better solution.
- Enable checkbox for padding even for non-installed
- To support the placeholder for non-installed extensions is part of the UI task.
- For non-add-ons, for now, we show the enable button but inactive.
- Proposal: to remove “(from file)” for the operators:
- “Install Extensions (from file)…” → “Install from Disk”
- “Install Legacy Add-on (from file)…” → “Install Legacy Add-on”
- Bolder proposal: to remove ALL text under ():
- Installed (Legacy) → Installed .. but use Legacy for the name. e.g., “Legacy: Blender Kitsu”.
- “Blender Kitsu (Outdated)” → “Blender Kitsu” (but uses the Update button).
- Nit picky:
- I would show the human-readable SPDX version of the (most common) license, not its slug:
- “GPL-3.0-or-later” → “GNU General Public License v3.0 or later”
Installation
- Implement drag & drop from URL.
https://extensions.blender.org/media/files/ed/1fec123.zip
- Implement install from clipboard.
- Support the same URL that can be dragged.
Server
Next planned tasks:
- Support deleting a version.
- Support deleting a whole extension.
Follow ups:
- Version 1 task list updated.
- New sub-tasks created:
