The meeting will be on 2024-01-11T17:00:00Z. It is open for everybody interested to join the video call (link below).
Present: Bassam Kurdali, Brad Clark, Christoph Lendenfeld, Dennis (Studio Galt Mocap), Eduardo Rubio, Jason Schleifer, Jeremy Bot, Marion Stalke, Nate Rupsis, Nathan Vegdahl, Sybren Stüvel
Links
- Video Call. Note that there are no recordings of the meeting. This way everybody is free to say or show anything.
- A&R Module Meetings calendar for inclusion in your own calendar
- Previous and next meeting notes
- Issues & Pull Requests
- Draft agenda for any upcoming meetings
- New face: David (Studio Galt Mocap), runs a GitHub repo on a project, animating American Sign Language, as “usable assets”.
- By now all relevant Wiki content is ported to the new platform: Blender Developer Documentation. More info at New Developer Documentation Platform - Migration Update
- People were pleased with using Jitsi for the previous meeting, so we’ll keep using it for the forseeable future.
Landed
Names are from the Git log.
- 73f968dbe57: Refactor: keyframing unit tests (Christoph Lendenfeld) (2024-01-05)
- d4ce5d6fc9e: Anim: add RNA getter for
bone_collection.is_visible_effectively
(Sybren A. Stüvel) (2024-01-05) - 66cdc112fc5: Anim: Bone Collections, replace
.move_to_parent()
with.child_number
(Sybren A. Stüvel) (2024-01-05) - 2e2b5dcd52a: Anim: Outliner, show bone collections in their hierarchy (Sybren A. Stüvel) (2024-01-08)
- 4fe6f0b271e: Fix: frame snapping for the time extend transformation mode (Alexander Gavrilov) (2024-01-08)
- 2274f2be4b5: Anim: fix Solo Bone Collection operator (Sybren A. Stüvel) (2024-01-08)
- 687d6932c07: Anim: ensure active bone collection doesn’t change when adding new one (Sybren A. Stüvel) (2024-01-08)
- ef5dd0e4511: Anim: fix Show All Bone Collections operator (Sybren A. Stüvel) (2024-01-08)
- 6d8bb7f73c2: Anim: armature.collections.move() now retains the active collection (Sybren A. Stüvel) (2024-01-08)
- d0ef66ddff5: Drivers: implement fallback values for RNA path based variables. (Alexander Gavrilov) (2024-01-08)
- b9074381e5d: Drivers Editor: apply red underline to drivers that failed evaluation. (Alexander Gavrilov) (2024-01-08)
- 015555b07a0: Anim: library override support for bone collection visibility (Sybren A. Stüvel) (2024-01-09)
- 5b8207fa97e: Anim: bone collection context menu, prevent operations on linked (Sybren A. Stüvel) (2024-01-09)
- 649eec7774e: Fix #116061: BoneCollection ID property user count handling incorrect (Sybren A. Stüvel) (2024-01-11)
Short-term goals / Ongoing Work
- High prio bugs:
- #116362: Timeline - Keyframe Precision Moving Not Working
- Christoph: outside the graph editor: ctrl hotkey used to disable snapping (3.6 and older). Now it snaps to seconds, as it’s very uncommon for animators to have no snapping at all.
- Christoph: roll back to old behaviour and disable snapping on Ctrl? Or accept the current state as “as designed”?
- Nathan: big difference between 3D Viewport and animation editors: in the former snapping is sometimes on, but usually off. In the latter, snapping (to frames) is the default behaviour, and having snapping off is hardly done.
- Animators present in the meeting do not want to have sub-frame keys at all.
- Nathan: a typical application is cleaning up motion blur sub-frames. Such work does not require frequent toggling between snapping & not-snapping. So then the ‘magnet’ icon in the toolbar would likely be good enough.
- Jason did something similar for editing motion blur, and it was very rare.
- Sybren: how useful is snapping to seconds?
- Marion: it can be used in layout, for camera switches etc. Communication with non-animators can be easier when talking about seconds.
- Bassam: It’s more about the danger of accidentally creating sub-frame keys by new users. They can be very confusing. So making it very easy to disable snapping can be dangerous.
- Decision: keep the behaviour of ctrl toggling to snapping on seconds, and close the bug.
- Christoph: will ask the reporter for more context about their workflow.
- #115978: FCurve extrapolation ignored in whenever anything is present in the NLA
- Nate has fix in #116382: Fix #115978: FCurve extrapolation ignored in NLA.
- Buildbot is failing on the linter, but likely due to the fix targeting Blender 3.6; the linter failure is unrelated to the code changed in this PR.
- #115915: Very strange constraint jiggling not present in blender 3.6.3
- Sybren is investigating a solution.
- #116061: Errors and crashes with BoneCollection properties due to “id_us_min: ID user decrement error” (already fixed)
- Nathan worked on documenting the bone collections data structure.
- Sybren created #116938: Anim: move ANIM_… bone collection functions into C++ style, such as the blender::animrig namespace, needs some discussion between developers on how to move for0ward.
- Christoph came back from holiday and worked on fixing bugs.
- Marion worked on design work for layered animation.
- Checked with other animators at work about this.
- Important: avoiding animating on the wrong layer. Can be done by coloring layers, and showing the color of the active layer in other animation-related editors (like the timeline).
- When editing an object that’s not on the currently active layer, show a warning.
- Animatable layer influence.
- Show keys from inactive layers as well (“shine through”), for syncing between them.
- Broader idea: have layers “sharable” between different “actions”.
- Merging layers, splitting layers, etc.
- Brad: offers to help with knowledge about layered animation workflows.
- Nathan: moving forward, we’ll work iteration-based so we can steer things quickly.
- Marion: offers making a “workgroup” for this so we can have extra meetings.
- Sybren: for video calls, just use the same URL as this meeting. It’s been added to the chat channel title bar.
Patch Review & Decision Time
- #116927: Fix #73524: Autokey inserts keyframes into the driver FCurve Fixed by removing a “feature” that might have never worked.
- Jason: it sounds like it doesn’t work as intended anyway.
- Marion: even when you’re working in the driver editor already that curve is already confusing.
- Decision: the “feature” can be removed.
- Sybren: A ‘Radial Basis Functions’ based tool would work much better for this.
from Jason and Jeremy.
- #117012: Fix #116138: make hidden bones show up in Properties when selected in Outliner
- #116492: UI: Reorganize ‘View’ menus in animation and video editors to make them more consistent
- Just generally good to get eyes on this, since it involves the animation editors.
- Nathan: more specifically, includes 12 additions to the Timeline’s menu that might converge the Timeline and Dopesheet further. Which additional timeline menu items make sense here?
- Nathan: let’s ask the author to separate “organising existing items” and “adding new items” into separate PRs.
- Sybren: good idea. Because we don’t want to have the timeline even more like the dopesheet.
- Christoph: In the design for the new animation system, should we also include designing a new timeline editor?
- Sybren: Good idea; might be a separate new editor, or a mode of The One Animation editor that it goes into when it’s slim enough.
- Nathan: there are header items in the timeline that aren’t in other editors, so we can’t just remove it.
- Marion: there are add-ons that add those items to all animation editors.
- Bassam: maybe it even makes sense to dumb down the timeline enough to have it always in view.
- Decision: split the PR into “organise existing menu items” and “add new ones”.
Next Meeting
The next meeting will be an off-schedule meeting on Tuesday 2024-01-16T11:00:00Z. Again it will be open for everybody who’s interested. The provisionary meeting agenda will be updated before the meeting.
