User Interface Module Meeting
Regular User Interface module meeting for planning and coordination.
Next meeting on September 26th, 2023.
Attendees
- Julian Eisel
- Brecht Van Lommel
- Pablo Vazquez
- Thomas Dinges
- Hans Goudey
- Harley Acheson
Merged Since Last Meeting
- Fix: Enter on the filebrowser filename label skips operator #111693
- UI: Highlight Selected Enum #111074
- UI: Header Status Text Changes #111676
- UI: Consistent Menu/Block/Popup Content Ordering #109798
- Compositor: Re-organize Add menu #111481
- Shading Nodes: Refactor Add menu #111798
- Texture Nodes: Refactor Add menu #111838
- Small changes to Edit and File Menus
- Spreadsheet menu now themeable
- UI: Node Grid Adjustments for Line Width #111640
- UI: Add canvas picker to paint modes in 3D Viewport #111756
- UI: support searching in menus #110855
- UI: Hide widget emboss if inner color is fully transparent #111980
- UI: Allow “New Window” While in Maximized Area #111999
- Geometry Nodes: Extend add modifier menu with node group assets #111717
- Fix #111017: Improvements to the drawing of Color Ramps #111903
- Fix: Outliner missing update adding asset nodegroups #111924
- Fix #102687: Use Proper Style for Label Length Estimation #111908
- Fix #111821: Fix Stats While in Sculpt Mode #111945
- UI: Do not repeat icon for Shape Key operators in modifier options menu
- UI: Use asset icon for “Mark Asset” in menus #112111
- UI: Add “Open Recent” Menu entry to F4 context menu #111701
- UI: Fix inconsistent menu background padding #111826
- Fix #112028: Ctrl+Alt+Scroll not working on all selected objects #112095
- Fix #112087: Float curve flickers with aligned points at x axis #112205
- Fix #112129: Remove Blank Items from “Region Toggle” Pie Menu #112193
- Keymap: Add Numpad Return to create newline in Text object edit mode #112277
Go / No-Go
- UI: Change menu icons of single-choice enums to radio buttons #111796
- Harley mentioned there might be an issue that he remembers from years ago, but that can just be fixed.
- UI: Window Title Changes #111998
- Campbell & Harley okay with dropping the path, allows eventually using OS title bar area.
- Pablo proposes
*test.blend [path/to/file/] - Blender 4.0 Alpha
- No agreement about the order here, but there is consensus about putting the version in here, without the subversion.
- The PR has been updated to hide patch level if zero and to use Pablo’s format.
- UI: Change Order of Lists in File Browser Sidebar #112114
- General agreement
Ongoing Projects
- UI: Display invalid cache as striped lines in the timeline #108481
- Stalled because of color choices, which we agreed were quite distracting. Other than that the PR makes sense though.
- Pablo will look at changing the theme colors, or the PR can dial back the opacity.
- UI: Unify Add menus #111746
- Pablo and Hans will meet soon to make an initial plan for the modifier menu.
- UI: Import obj files by drag and drop #106871
- Guillermo says it will be replaced by #111242
- Other than that, the work is still in progress. It definitely makes more sense for this to be generalized not to just one format though.
- Remove ‘Edge Highlight’ overlay toggle #111431
- There was a lot of back and forth, but there’s general movement towards consensus. We spent some time trying to clarify the history and different people’s opinions about the changes.
- It’s not clear that we want to add more theme settings.
- The description of the PR needs to be updated to describe the latest change. See Ingredients of a PR.
- UI: Possible Change of Interface Font #112209
- The change proposes changing to a modern font that’s specifically designed for UIs. There was agreement about Inter, though the kerning would be worse until we support better complex shaping.
- Doing the change in 4.1 might be better, but it’s nice to put a visible UI change in a large version bump. As the developer, Harley can make this work in 4.0.
- BLF: Subpixel Positioning, Anti-aliasing, Hinting #105441
- UI: Theme: Allow transparency when editing text in widgets #112090
- Straightfoward, change, Julian will review.
- Preview Sizes, decide between:
- UI: Allow Integer Thumbnail Size Range #105815
- This patch was preferred.
- UI: Size Range of Preview Thumbnails #108557
- Having a more flexible range was preferred.
- VFont: Use BLF for font & glyph loading #110187
- This brings us closer to unifying the text features. The PR needs code review from Campbell.
- It’s unclear how the change interacts with font and glyph caching. Julian mentioned that text object and UI caches shouldn’t interact.
- UI: Dynamic File Browser Tooltips #104547
- There was agreement about the general idea.
- The text is very dense. It might be helpful to remove some of the information so we don’t just include things in the tooltip because we can.
- The file name should stand out from the other information. Would require something like #105905
- UI: Cleanup Dialog to Manage Orphaned Data #106653
- Pablo will have another look at the design.
- UI: Improved Window Titles #111495
- It’s an improvement over the current situation which is basically useless.
- Shows the name of the editor for child windows instead of just “Blender <2>”
- Fix #72093: Collapse Wide Enum Lists to One Column #105386
- Needs review from Campbell.
- Viewport: Split object/mode overlays into its own popover #112156
- It makes mode-specific overlays signfiicantly more discoverable.
- The change exposes weirdness with the existing polls for object-specific options. For example, grease pencil is a special case, since it shows overlay options only based on the active object. That feels weird, but maybe not bad.
- Viewport: Show Add menu if nothing is selected #112112
- This is similar to recent changes in the node editor.
- Some of the choices are arbitrary, but we agreed the choices were worth exploring.
- Outliner: Double-click on item icon to select contents/hierarchy #110151
- Julian will have a look at the PR.
- Menu search
- The feature could still use a bit of polishing
- Put the top left of the search menu at the same location as the top corner of the initial menu
- Add the “Search” icon in the header with the tooltip text of “Type to Search”
- There are some issues with IME entry
- The first character could be added to the initial IME text search, though it may be trickier than this
- Ask Yiming for help
- #111538: Modifiers UI Overhaul
- Add modifier menu
- The menu still needs reorganization, which should help the workflow.
- Hans will look at scrolling and resizing UI views
- Julian will look into selection for view items
- Add modifier menu
- #112241: Asset Shelf: Transparent asset shelf header with background for buttons
- Asset shelf can be done in main already
- We might want to do more polishing before enabling it at the top, but it’s also an improvement over main
Other
- Private meeting room at Conference for UI Meeting + Guests
- UI Development Presentation/Roundtable?
