User Interface Module Meeting
Regular User Interface module meeting for planning and coordination.
Next meeting on September 13th, 2023.
Attendees
- Harley Acheson
- Julian Eisel
- Pablo Vazquez
Merged since last meeting
- Fix #89479: Unable to select hierarchies of multiple objects from outliner #104737
- Approved, Merged.
- Fix #93685: Allow Outliner Drag to Other Windows #105196
- Approved. Brecht reviewed. Merged.
- UI: Make 3D Viewport header transparent #109735
- Approved. Harley has different implementation, now merged.
- Pablo will follow up with possible theme changes.
- Blender 4.0 - Remove Vignetting from Default Theme #106699
- Approved, Pablo handled. Merged.
- UI: Allow Eyedropper Outside of Blender #105324
- Approved. Brecht Reviewed. Merged.
- UI: Fix scrollbar highlighting outside of regions #105973
- Design Approved. Harley will Review. Merged.
- File Browser: Add âQuick Accessâ items to sidebar on Windows #108431
- Approved. Ray Approved. Merged.
- UI: Statistics Overlay Improvements #104663
- Approved and Merged.
Ongoing Projects
- UI: Highlight Selected Enum #111074
- Unify list and view theme settings. Hover effect will be
innerwith +10% opacity.
- UI: Consistent Menu/Block/Popup Content Ordering #109798
- Ready to go! Julian will do code review.
- UI: File Loading Dialog #104666
- Harley will update layout based on design by Pablo.
- UI: Split mode overlays into its own popover #111624
- Agreed. Needs design tweaks by Pablo.
- Fix #72093: Collapse Wide Enum Lists to One Column #105386
- Use number of columns to decide when to show a single list. If number of items > X, show search dialog.
- Outliner: Double-click on item icon to select contents/hierarchy #110151
- Pratik reviewed. Needs update from developer for further reviewing.
- Compositor: Re-organize Add menu #111481
- Agreed. Design ongoing.
Feedback
- UI: Placeholder in Text fields #111436
- Agreed. Harley will work on it.
- Design feedback is that it should be more subtle.
- Always shown unless there is content in the field.
- UI: support searching in menus #110855
- Design discussion ongoing.
- Change Edit Mode Edge Highlight default to âonâ #111431
- Remove overlay setting, but use it internally when Vertex+Edge select mode is on (to help tell them apart).
- Bug: header background issue when using modal operators
- Agreed on remove the background transparency change and simply show the values on top of whatever is there.
- Show values in the toolbar, if present.
- Modifiers UI #111538
- Agreed.
- MVP: Use UILists, show active modifier only.
- Use UI Views with drag nâ drop.
- Support scrolling for UI Views.
- UI: Import obj files by drag and drop #106871
- Needs a more generic implementation, that also supports add-ons to register their supported formats.
- Needs code design.
- Shading Nodes Preview Type
- Team agrees that itâd make sense to use the material preview enum.
Help Needed
- macOS patches:
- Fix #89906: Consistent track pad zoom directions #111141
- Needs code review.
- UI: Replace list of workspace add-ons with a UIList #111272
- Agreed. Needs developer.
Next
Team agrees on having a look at current UI papercuts, to organize them, prioritize, and better define potential good first issues for the community to contribute to.
Practical Info
This is a bi-weekly video meeting to plan and discuss development in the User Interface module in Blender. Any contributor (developer, UI/UX designer, writer, âŚ) working on user interface topics in Blender is welcome to join and add proposed items to the agenda.
