The meeting was on 2023-09-07T16:00:00Z. It is open for everybody interested to join on Google Meet (link below).
Present: Alexander Gavrilov, Charles Wardlaw, Christoph Lendenfeld, Fani-Eleni Pandi, Ingo Clemens, Jason Schleifer, Jon Matthis, Michael Kowalski, Nate Rupsis, Nathan Vegdahl, Felipe G, Sybren Stüvel
Links
- Google Meet. Note that there are no recordings of the meeting. This way everybody is free to say or show anything.
- A&R Module Meetings agenda for inclusion in your own calendar
- Previous and next meeting notes
- Issues & Pull Requests
- The Bone Collections feature was received with great enthousiasm on Blender Today.
- Sybren back from holiday.
Landed
- 11fe57cab8a: Animation: Move Snapping to Scene (Christoph Lendenfeld)
- #110788: Animation: Graph Editor - Don’t draw curve points if they are too close to each other (Christoph Lendenfeld)
- b7a84c49eac: Animation: Keep icons aligned when curves are baked (Christoph Lendenfeld)
- 8134849b120: Fix: Graph Editor extrapolation line drawing issue (Christoph Lendenfeld)
- Bone Collections related:
- 3cac6639: Rigify: update metarigs and samples to work with bone collections. (Alexander Gavrilov)
- 5ec3aa7d: Rigify: update code to work with bone collections instead of layers. (Alexander Gavrilov)
- 136b3111965: Fix #111789: Anim, bone collections not created when linking armature (Sybren A. Stüvel)
- fc02d5ee1118: Fix (unreported) crash in versioning code of the new Bone Collections. (Bastien Montagne)
- bcd0198a46d: Anim: versioning, also bone create collections for empty bone groups (Sybren A. Stüvel)
- d5b9127e1b2: Fix: free BoneCollection ID props when the collection is freed (Nathan Vegdahl)
- b0d5f3dc224: Fix #111711: bone collection visibility cannot be overridden (Philipp Oeser)
- e6bb1374f9c: Anim: add bone collection custom properties sub-panel (Sybren A. Stüvel)
- a6bb302f9f5: Anim: show Bone Collections panel when armature is pinned (Sybren A. Stüvel)
Short-term goals / Ongoing Work
- Brad Clark: Animation 2025 “Flow state” design roadmap
- Christoph: graph editor performance:
- Christoph: next stop is dopesheet.
- Nathan:
- #111780: Bone collections and bone collection membership are not handled properly when undoing in armature edit mode
- New data model: Rationale: Animation-hook-up Pointer Direction
. Module is in agreement about how to move forward.
- Sybren: #108941: Animation: Replacing bone layers + groups with bone collections
- Upgrade Guide: Bone Collections Upgrade Guide - HackMD
- Sybren: asking for TD/Rigger feedback about whether the ‘if you did this, now do this’ Python code is complete.
- Sybren instantly realises something is missing (‘which collection has this bone’ queries).
- Alexander:
bone1.layer = bone2.layer
- Nate:
- Working on finalising Bake Action work by Colin Bassnett to get it landed.
- Working on NLA Action influence keying
Patch Review / Discussion / Decision Time
#111931: USD: Support armature and shape key export
- Michael (NVIDIA) working on this. Idea is export of armatures → usdskel + shapekeys → usd blend shapes.
- A UsdSkel importer is also underway.
- Discussion in #pipeline-assets-io-module channel.
- Challenge: Modifiers on top of the Armature modifier, especially when they change the vertex count, things get difficult. USD assumes mesh topology matches the blend shapes, whereas Blender’s evaluated mesh might be different.
- Open question: what should the default be for deformed mesh exports? On (use UsdSkel deformation) or off (write geometry caches)?
- Charles: should be ON, as many people exporting will be for import into a game engine.
- Sybren: ON will also cause faster roundtrips, as having that by mistake will be faster & produce smaller files than exporting geometry caches. So correcting such a mistake will be ‘cheaper’.
- Nathan: USD, coming from Pixar, is more for the film production use case, which would suggest OFF is a more suitable default. Also agrees with Sybren.
- Charles: Pixar doesn’t layer deformers (like other companies like Sony or Disney), so exporting those to USD will likely be working without loss (i.e. not need full geometry caches). This would still be using it also as sort of a cache, but then caching a complex rig down to a simpler set of deforming bones in USD.
- Michael: another issue is choosing which shapekeys to export.
- Exporting all could be exporting too many, bloating files.
- Skipping them based on which modifiers use them could work.
- Nathan: probably better to have users manually specify that, to avoid surprises.
- For proper support, Blender needs to be able to handle mirrored bones. Mostly X-mirrored for symmetry, hence with
scale.x = -1
and thus negative determinant. - Charles suggested (in Blender Chat) that adding “a
float[3] rest_scale
to theBone
struct that is only taken into account when building the rest arm mat” might be enough. Would need to be heavily tested. Maybe Paul Kanyuk (Pixar, also involved in the#pipeline-assets-io-module
chat channel) can give a simple setup to start working on this? - Charles: might not be a good idea though, as constraints might have a hard time dealing with matrices like this. This kind of mirroring makes copy-pasting animated values / curves from one side to the other super simple, as that wouldn’t require flipping the animation data. He would do this at the control level, though, and not the bone level.
- Nathan: shares worries about the constraint code, as there are lots of assumptions in there.
- Alexander: also ‘Preserve Volume’ and bendy bones could add more complications.
- Charles: even if it works for IK joints and driving things, it might be enough. But probably better to wait until Pixar releases OpenExec (Open Source version of Presto’s constraint evaluation engine).
- Sybren: might be too much effort & risk to work on for now, if the goal is ‘only’ to support Pixar assets.
- Nathan: it could fit in a future redesign of more generalisations in Blender’s armature system.
- Charles: having arbitrary rest positions in Blender could be a way to get this in, without having it as a feature in the UI.
- Sybren: that would be much more preferred, and that fits in better with the current plants of the module.
- Charles: could also be super helpful for quadriped-to-biped transitions of characters, where a 4-legged character can also move as a biped.
- Alexander: do you need
float[3]
? Or would a boolean like “flipped X” be enough? - Charles: yes, as Pixar sometimes uses nonuniform floats, so
(-0.5, 0.75, 1.0)
kind of vectors. - Alexander: what of sheer?
- Charles: that’s for the rigger to handle.
Charles: (in context of the above): it might be a good time to have ‘joint draw mode’.
- Sybren: you mean #106230 - WIP: anim/armature-mode-spheres - blender - Blender Projects ?
- Charles: Yeah. Having the bone shape itself drawn instead of the dotted line would be fantastic.
- Sybren: the orientation of the octa would be meaningless though.
- Charles: that’s fine.
- Jon: this matches my intuition (as mocap handler) much more.
Decide on a color of keys if the curve is locked. #111986: Animation: Graph Editor locked key drawing
- Currently it’s an ‘x’ for locked keys, as it’s also used for baked curves.
- This PR changes them to be grey, which matches disabled curves. They are similar (i.e. read-only) but are evaluated differently.
- Sybren: the curve itself will be different between locked and disabled.
- Sybren: maybe tiny dot?
- Jason & Nathan: like the idea.
- Nate: Square?
- Jason: likes that too.
- Christoph: distinguishing square from round might not work at certain resolutions / UI scales.
- Sybren: using shapes for locked/unlocked might make them unavailable for other purposes. Not sure if locking is an important enough feature.
Two PRs for the same thing:
- #110903: Animation: Add channel type options to the Bake Action operator by Colin Bassnett, and
- #111997: Animation: Add channel type options to the Bake Action operator by Nate Rupsis.
- Nate: use mine.
Christoph’s proposal: Removing Baked FCurves
- Consensus in the thread: do not remove them, but rename them to avoid confusion.
- Christoph: has a PR for better FCurve baking, with stepping, baking FCurve modifiers, etc. That makes them actually useful.
Felipe’s Non-Rigged Lines
Felipe quickly discusses his “non-rigged lines” system, drawing lines on top of rigged & deformed mesh.
- works like ‘hair curves’ assets, by sampling curves in UV-space.
- will provide demo file.
- Will we get weight groups for curves? Now you need a hook per point of the curve. Even setting the weight manually per point would be nice already.
- Will continue discussion in the module chat, especially since Spiderverse linework was mentioned, and Charles worked on Spiderverse.
Next Meeting
The next meeting will be on Thursday 2023-09-14T16:00:00Z. Again it will be open for everybody who’s interested. The provisionary meeting agenda will be linked in the #animation-module channel before the meeting.
