The meeting will be on 2023-06-01T16:00:00Z. It is open for everybody interested to join on Google Meet (link below).
Present: Armin Halac, Brad Clark, Christoph Lendenfeld, Daniel Salazar, Denys Hsu, Eduardo Rubio, Jason Schleifer, Marion Stalke, Nate Rupsis, Nathan Vegdahl, Nitin Rawat, Paolo Amadini, Paul Thuriot, Sybren Stüvel
Links
- Google Meet. Note that there are no recordings of the meeting. This way everybody is free to say or show anything.
- A&R Module Meetings agenda for inclusion in your own calendar
- Previous and next meeting notes
- Issues & Pull Requests
- New face: Paolo Amadini, interested in helping out with development.
- Nate: a good way to get into the development workflow could also be to help updating the manual, to get familiar with Git, pull requests, reviews, etc.
- Blender 4.0 development has started.
- Backward incompatibilities should be listed in #105523: Breaking changes for 4.0
- Tomorrow: Code Quality Day
Landed
Blender 3.6:
- e2a75814ac9: Animation: change Slider Popup menu hotkeys
- d36c329e16e: Fix crash when selecting all bones in armature
- e233507efd9: Fix: Channel select keys doesn’t add undo step
Blender 4.0:
adef3a4556a: Animation: Remove collection hotkeys from pose mode
- Brecht (on the PR): remove those keys globally, so also from object mode.
- Sybren & Christoph: even though we’d personally like this, that’s a different discussion & use case.
- Nathan: those hotkeys are bizarre, given the arbitrary number of collections & their hierarchy.
- b95cf5ff0f3d: Animation: Update NLA “TAB” tweak mode to be full stack evaluation
Short-term goals / Ongoing Work
#107281: Fix #100718: NLA Hold Forward Inconsistency
- Wayde Moss has a PR.
- Sybren doesn’t quite understand the bug, demo file is a bit of a mess, but trusts the other reviewers that the issue is actually solved.
- Nathan can take another look w.r.t. functionality.
- #107990: Animation: NLA Vertical Reorder
#107653: Paint: Add loop select for faces
- Christoph: Next PR is loop select for vertices, which will be the last one for the overarching design task (#99113).
#106801: Assigned action is lost if file is saved while in NLA tweaking mode on a linked armature with both object and data animation
- Nathan found the root cause, Bastien Montagne will review.
#108286: Animation: Make Vertex Weight Edit modifier inclusive
- Ready for review
Nathan & Brad are working on a new animation data model proposal.
- Nathan: “definitely not done yet”
Sybren is working on a control rig prototype Powership.
- PR by Denys Hsu #1: Motion transfer setup
- Discussion about node outputs when they cannot be computed (like division by zero).
Sybren proposes to use ‘safe’/‘normal’ values as much as possible (so
x/0
is0
and not infinity/NaN/error), until we have a debug mode to visualise and trace such ‘special’ values. - Module agrees that this is a good approach.
- Marion will look into ‘solo’ icon for the NLA tracks.
Patch Review & Decision Time
#107173: Refactor: Bidirectionality on Graph Editor Sliders #107173
- Christoph proposes a change to slider operators. Currently many of them work in the 0-100% range, with 50% as a neutral value. He proposes change such sliders to a 0% neutral value and go from -100% to 100%.
- Decision: module agrees this is a good change, will land in 4.0
#108257: Fix #108229: Wider tolerance shuffling NLA strips
- Nate: fix makes sense at first glance, will look into it further soon.
#108134: Fix #32022, #43188, #100373, Armature modifier - Preserve volume + Scale
- Nathan likes to get a consensus if we should merge it once it’s ready, given that it’s only a partial fix.
- Fixes only uniform scaling, where both bones in a bendy joint have the same scale factor.
- Brad: this is not an issue to just Blender, other tools also patch various issues. Two other variations of solutions are described in Dual Quaternion Skinning with scale - Rodolphe Vaillant's homepage, but that document also links to patents…
- Sybren: use this to address other issues with dual quaternions (like non-uniform scaling, shear, etc.)? Nathan: only if we have time, let’s land this first.
- Nate: is this a breaking change? As it changes mesh deformation? This should be documented as such.
- Decision: can land in 4.0 as it does make the dual quaternion skinning a lot more useful.
- Marion: would this address other issues with scale for game animation export? Brad: not really, it’s a separate thing.
- Daniel: can, in the future, dual quaternions be managed by weight groups, so that it’s only used for part of the mesh and can be blended?
- Nathan: that’s one of the use cases for the ‘Multi Modifier’ checkbox of the ‘Armature’ modifier. So that’s already in Blender.
#108296: Regression: Cannot Overwrite Pose in Pose Library
- Brad: updating poses is under-documented, is a usability issue.
- Module agrees, even updating an existing pose in the current blend file is hard.
- Sybren: this should be revisisted then.
- Brad: sliding & blending poses seems to be broken too. Christoph can help with this.
Nate: Adi Sage, in Blender Chat, proposes some alternative keymap for switching between animation editors in a consistent way.
- Brad: there currently is no way to use a hotkey to switch to the NLA.
- Sybren: could be a good Right Click Select proposal.
- Nathan: never uses Shift-Fx keys for this, as it requires taking his hand off the mouse. How about having a pie menu for this?
- Module: definitely room for improvement here.
#107950: WIP: VSE Experiment in Mouse Cursor and Transform Status Feedback
- Brad: this requires further discussion on right-click-select vs. left-click-select interaction models, and their effect on selection vs. manipulating strips vs. manipulating the playhead.
Next Meeting
The next meeting will be on Thursday 2023-06-08T16:00:00Z. Again it will be open for everybody who’s interested. The provisionary meeting agenda will be linked in the #animation-module channel before the meeting.
