2.81 Sculpt Mode - "Rotate Brush" should be named "Warp Brush"
The result is literally warping mesh and
There is also a gizmo tool called “Rotate” which shares the same name
I agree that the naming is somehow conflicting with the rotate gizmo, but it’s not warping. Infact it’s really rotating.
But its a brush not a gizmo as you said. Some renaming should take that into account instead.
Sometimes it seams comparable to warping, because as a brush its tweakable with options like symmetry, brush size, falloff radius, etc.
It spans a sphere with the brush radius and anything inside is moved according to the falloff.
So a big constant brush without symmetry is a clean rotator.
Everything more warplike comes from symmetry and a nonconstant falloff.
rotatebrush
rotatebrush2
Rotate seems fine to me. A brush is different from a tool, so there’s no confusion imo.
In zbrush it’s called Spiral, BUT only because the center action point of the brush moves when you move the cursor…
2019-11-28_18-49-55
unlike the rotate in blender where the center action point of the brush always stays where you started
2019-11-28_18-52-50
So, rotate is fine. :slight_smile:
