16 March 2026
Announcements
Modules & Projects
- 2026-03-10 Nodes & Physics Module Meeting
- 2026-03-10 Animation & Rigging module meeting
- 2026-03-13 User Interface Meeting
- 2026-03-13 Projects Updates meeting
- 2026-03-16 Grease Pencil Module Meeting
New Features and Changes
Anim
- Convert to correct rotation mode when applying pose (commit) - (Christoph Lendenfeld)
Compositor
- Use integer vector sockets where possible (commit) - (Omar Emara)
- Add Minimum and Maximum outputs to Levels node (commit) - (Habib Gahbiche)
- Support matrix sockets (commit) - (Omar Emara)
- Support relevant ID sockets (commit) - (Omar Emara)
- Port Active Camera and Camera Info nodes (commit) - (Omar Emara)
- Port matrix math nodes (commit) - (Omar Emara)
Cycles
- Fix orthographic camera motion and motion pass toggle (commit) - (Patrick Mours)
DRW
- Bump Draw call structure instance limit (commit) - (Clément Foucault)
EEVEE
- Port SubSurface Scattering shaders to BSL (commit) - (Clément Foucault)
- Reset on playback (commit) - (Miguel Pozo)
Geometry Nodes
- Add âSet NURBS Weightâ node (commit) - (Romain Guimbal)
- New experimental Split String node (commit) - (Jacques Lucke)
- New Trim String node (commit) - (Jacques Lucke)
IMB
- Add span version of
IMB_blend_color_float(commit) - (Sean Kim)
Nodes
- Reassign selection when extending Group Input/Output nodes (commit) - (quackarooni)
Overlay
- Add proper support for AA in skin root shader (commit) - (Clément Foucault)
Paint
- Add support for 3D brush cursor in Vertex & Weight Paint (commit) - (Sean Kim)
Sculpt
- Add âAdd Primitiveâ tool defaults (commit) - (kunal)
- Add âScene Projectâ brush asset (commit) - (Sean Kim)
UI
- Show linked/overridden/asset state icon in data-block enum selectors (commit) - (Julian Eisel)
- Add âSave Modified Imagesâ dialog when saving blend file (commit) - (T0MIS0N)
- Enable Vulkan tests by default (commit) - (Christoph Neuhauser)
- Fix SVG Icon Rotation (commit) - (Harley Acheson)
- Improved CJK Unicode Ranges (commit) - (Harley Acheson)
- Fix Area Snapping Above With Playback Controls (commit) - (Harley Acheson)
XR
- Controller bindings deadzone threshold improvements (commit) - (Jonas Holzman)
- Implement a separate XR-specific Blender context, accessible from XR draw handlers (commit) - (Jonas Holzman)
Weekly Reports
- Aaron Carlisle
- Alaska
- Bart van der Braak
- Bastien Montagne
- Campbell Barton
- Casey Bianco-Davis
- Christoph Lendenfeld
- Clément Foucault
- Dalai Felinto
- Falk David
- Guillermo Venegas
- Habib Gahbiche
- Hans Goudey
- Harley Acheson
- Jacques Lucke
- Jeroen Bakker
- Jesse Yurkovich
- John Swenson
- Jonas Holzman
- Julian Eisel
- JulienDuroure
- Lukas Tönne
- Kévin Dietrich
- Mark van de Ruit
- Martijn Versteegh
- Miguel Pozo
- Nathan Vegdahl
- Nika Kutsniashvili
- Omar Emara
- Pablo Vazquez
- Philipp Oeser
- Pratik Borhade
- Richard AntalĂk
- Sean Kim
- Sebastian Herholz
- Sergey Sharybin
- Sybren StĂŒvel
- Tariq Sulley
- Thomas Dinges
- Weizhen Huang
- Wu Yiming
