Welcomes
- Thomas Dinges starts full-time as Developer Community Coordinator on November 1st.
- Philipp Oeser is now the go-to developer for the LTS releases.
Announcements
- Blender 3.0 is now in bcon3, and 3.1 is in alpha.
- Blender 3.x roadmap by Ton Roosendaal.
Modules & Projects
Core
Geometry Nodes
New sample files:
- Cupcakes by Sanctus
Render
New Features and Changes
User Interface
- Theme refresh for Blender v3.0 (commit) (Pablo Vazquez)
- Use text highlight theme color for active tab (commit) (Pablo Vazquez)
- Improve layout of custom property edit panel (commit) (Hans Goudey)
- Font picking improvements
- Node editor
- Animation editors
Cycles
- Distance Scrambling option to improve performance in some cases (commit) (Mathieu Menuet)
- Scrambling distance for the PMJ sampler (commit) (William Leeson)
- Improve performance with a more accurate volume stack size calculation (commit) (Sergey Sharybin)
- Add additive AO support through Fast GI settings (commit) (Brecht Van Lommel)
- Restore denoising depth pass when enabling denoising data passes (commit) (Brecht Van Lommel)
- Change Position render pass to be not antialiased (commit) (Brecht Van Lommel)
- Various user interface tweaks (commit, commit) (Brecht Van Lommel, Alaska)
Asset Browser
- Improved drag and drop support for object assets
- Drop object assets and associated objects at the cursor location (commit) (Campbell Barton)
- Improved feedback when dropping is not possible on drag and drop (commit) (Julian Eisel)
- Add visual feedback and snapping when dragging an object asset (commit, commit, commit) (Germano Cavalcante)
- Disable snap-dragging when linking object assets (commit) (Julian Eisel)
- Enable object asset support by default (commit) (Julian Eisel)
- Activate catalog after adding (commit) (Julian Eisel)
- Support dragging catalogs to move them in the hierarchy (commit, commit) (Julian Eisel)
- Show disabled-hint when dragging external assets over catalog (commit, commit) (Julian Eisel)
- User interface layout improvements
- Changes to various button padding and size (commit, commit, commit) (Julian Eisel)
- Improve hint for asset library that isn’t found (commit) (Julian Eisel)
- Rename “Default” asset library to “User Library” (commit) (Julian Eisel)
- Apply search filter to tags as well (commit) (Sybren A. StĂĽvel)
- Add Assets menu to the 3D View’s Object menu (commit, commit) (Sybren A. Stüvel)
- Be more accepting of backslashes as separators in catelog paths (commit) (Sybren A. StĂĽvel)
- Add Author field to asset metadata (commit) (Julian Eisel)
Virtual Reality
- Controller-based Navigation (commit) (Peter Kim)
- View adjustments to allow variable viewer scale (commit) (Peter Kim)
Geometry Nodes
- Image texture node (commit) (Jacques Lucke)
- Support viewing field values from the viewer node in the spreadsheet (commit) (Jacques Lucke)
- Rename geometry sockets to hint about what types they work on (commit, commit) (Hans Goudey)
- Geometry component type warning system (commit) (Jacques Lucke)
- Random/Stable ID changes
- Handle multiple grids in the volume to mesh node (commit) (Hans Goudey)
- Use vector socket for offset in Set Position node (commit) (Jacques Lucke)
- Add “Fill Caps” option to curve to mesh node (commit) (Hans Goudey)
- Add Brick Texture node (commit) (Charlie Jolly)
- Performance improvements
- User interface tweaks
- Add image socket to switch node (commit) (Johnny Matthews)
- Use true as default in Set Shade Smooth node (commit) (Jacques Lucke)
- Change default raycast direction (commit) (Jacques Lucke)
EEVEE
- Support accessing custom mesh attributes from geometry nodes (commit) (Kévin Dietrich)
Video Sequence Editor
- Support basic selection & delete from previews (commit) (Campbell Barton)
- Various preview selection improvements (commit) (Campbell Barton)
- Expose preview transform operators in menu (commit) (Aaron Carlisle)
Modeling
- Allow right click to cancel when no cuts have been made (commit) (Cian Jinks)
Line Art Modifier
- Allow trimming edges right at the image border (commit) (Yiming Wu)
- Add the ability to use a custom camera (commit) (Yiming Wu)
- Add option for offsetting generated strokes towards the camera (commit) (Yiming Wu)
