Hi everyone! I would like ask you if it’s possible assign numbers as shortcut for the workspaces. I have searched the assign shortcut with right click but it doesn’t appears. I have tested remove the hidden collection shortcut for assign this keymap but they aren’t a link command option. Can you help me? Thanks. Regards.
Try this solution. Not sure if it’s still work in 2.92 but it worked in past.
Thank you very much @Forester64 , but the problem is the context att don’t appears
@pablovazquez
