Windows: How would I fix clangd intellisense for Blender?
Everything builds just fine using the make.bat (debug development)
Do I have to update the compile_commands.json after building/installing deps (and if so, how would I do that)?
Any knowledge appreciated <3
If you run cmake.exe -DCMAKE_EXPORT_COMPILE_COMMANDS=ON followed by other options, it should create/update compile_commands.json as needed in the build folder. One doesn’t need to build stuff to create the json file that way.
You might need to set that path in VScode/project settings though.
https://wiki.blender.org/wiki/Developer_Intro/Environment/Portable_CMake_VSCode#C.2FC.2B.2B_Intellisense
https://cmake.org/cmake/help/latest/variable/CMAKE_EXPORT_COMPILE_COMMANDS.html
Although clang on windows for blender is not tested regularly, so not a guarantee that you’ll succeed in making it work. Visual studio is recommended.
