Windows - Blender as a Python Module with Optix: Build Errors
Hello,
I am successfully building bpy with and without CUDA support.
One build eludes me however: Optix. It leaves me with a very cryptic message, the end of CMake configuration fails with this to say:
-- 64 bit compiler detected.
-- Visual Studio 2017 detected.
-- Found OpenGL: opengl32
-- Found OpenMP_C: -openmp (found version "2.0")
-- Found OpenMP_CXX: -openmp (found version "2.0")
-- Found OpenMP: TRUE (found version "2.0")
-- Found OptiX: C:/ProgramData/NVIDIA Corporation/OptiX SDK 7.0.0/include
CMake Error at intern/cycles/CMakeLists.txt:316 (if):
  if given arguments:
    "EQUAL" "8.0"
  Unknown arguments specified
-- Configuring incomplete, errors occurred!
See also "C:/Users/TGubs/Code/Python/blenderpy/build/temp.win-amd64-3.7/Release/build/CMakeFiles/CMakeOutput.log".
error: command 'C:\\Program Files\\CMake\\bin\\cmake.exe' failed with exit status 1
I’m not sure how to proceed, and am trying to build at 2.82, but Cmakelists.txt does not have this
"EQUAL" "8.0"
Quoted in this way. For example, after checking out v2.82 I get the following:
if(${CUDA_VERSION} EQUAL "8.0")
      set(MAX_MSVC 1900)
Can anyone help explain to me what is going on?
Thanks in advance.
Probably CUDA_VERSION is not set in your CMakeCache.txt? It can be set to whatever the CUDA toolkit version is that you are using, e.g. 10.1 or 10.2.
@brecht pretty sure i have seen this, i think if you have optix on but cubins off it does (or used to do) this, we should probably have better flags checking there
think i fixed this in https://developer.blender.org/D7400 what git hash are you building off?
Yes, I think this is fixed already.
This seems to be about building v2.82, so maybe a workaround by editing the CMakeCache.txt can help.
Do you think that another possible workaround would be to build Optix WITH_CYCLES_CUDA_BINARIES=ON?
I’m going to try that and see if it helps. I would like to avoid modifying CMake files if I can help it.
Yes, prrior to D7400 landing, WITH_CYCLES_CUDA_BINARIES had to be on if you are building with Optix.
Thanks a lot! The build completed, interestingly not much larger than the CUDA build!
