BD3D
#1
Hello
Basic question:
why python users aren’t allowed to display operators properties within a panel for example ?
we can pass the args via the UI but we can’t display and interact with them within the UI, why so ?
any trick in the book to do so ? witouth generating another Group of Properties elsewhere ofc
kaio
#2
You can, but you’d need to define the callback for the operator properties’ update function. Just have the callback call bpy.ops.undo_redo()
import bpy
def redo(self, context):
if not redo.block:
bpy.ops.ed.undo_redo()
class VIEW3D_PT_custom_redo_panel(bpy.types.Panel):
bl_label = "Custom Redo Panel"
bl_space_type = 'VIEW_3D'
bl_region_type = 'UI'
bl_category = "Tool"
def draw(self, context):
op = context.active_operator
if op and op.bl_idname == "OBJECT_OT_simple_operator":
layout = self.layout
col = layout.column()
for prop in op.properties.keys():
col.prop(op.properties, prop)
class OBJECT_OT_simple_operator(bpy.types.Operator):
bl_idname = "object.simple_operator"
bl_label = "Simple Object Operator"
bl_options = {'REGISTER', 'UNDO'}
location: bpy.props.FloatVectorProperty(update=redo, size=3)
hidden: bpy.props.BoolProperty(update=redo)
def execute(self, context):
context.object.location = self.location
context.object.hide_set(self.hidden)
return {'FINISHED'}
# Block the initial callback.
redo.block = True
self.location = context.object.location
self.hidden = not context.object.visible_get()
redo.block = False
return self.execute(context)
if __name__ == "__main__":
bpy.utils.register_class(VIEW3D_PT_custom_redo_panel)
bpy.utils.register_class(OBJECT_OT_simple_operator)
BD3D
#3
thanks for the answer
yes but impossible to do so for non active operator right ?
for example: let the user define the parameters in the UI using the operator properties (and only thoses) then clicking on execute
This could be so handy
kaio
#4
That’s even easier. Just use the keymap item’s operator properties
import bpy
def execute_func(self, context):
col.prop(kmi.properties, "location")
col.prop(kmi.properties, "hidden")
op = col.operator("object.simple_operator", text="Execute")
op.location = kmi.properties.location
op.hidden = kmi.properties.hidden
hidden: bpy.props.BoolProperty()
return {'FINISHED'}
kmi = bpy.context.window_manager.keyconfigs.addon.keymaps['3D View'].keymap_items.new("object.simple_operator", "NONE", "ANY")
BD3D
#5
wow going trough a keymap to do so ? interresting !
thanks for the tip, i will investigate
