Blender launch very slow. It gets stuck with the gray screen.
The PC: i9 and Nvidia 3090
I’ve been working with blender the last few months without any issues. Today I’ve restarted Blender and then it’s taking too long, around 20 minutes. I’ve uninstalled, reinstalled Nvidia drivers, removed the Blender Fundation folder located in Roaming but still getting the same issue. Any ideas? Thank you
blender.exe --debug
PS C:\Program Files\Blender Foundation\Blender 3.0> ./blender.exe --debug-all
Switching to fully guarded memory allocator.
Read prefs: C:\Users\Myuser\AppData\Roaming\Blender Foundation\Blender\3.0\config\userpref.blend
graph_id_tag_update: id=SCScene flags=LEGACY_0 source=USER_EDIT
graph_id_tag_update: id=GRScene Collection flags=COPY_ON_WRITE source=USER_EDIT
graph_id_tag_update: id=SCScene flags=COPY_ON_WRITE source=USER_EDIT
graph_id_tag_update: id=GRCollection flags=COPY_ON_WRITE source=USER_EDIT
graph_id_tag_update: id=GROVERRIDE_RESYNC_LEFTOVERS flags=COPY_ON_WRITE source=USER_EDIT
graph_id_tag_update: id=GRScene Collection flags=TRANSFORM, GEOMETRY, COPY_ON_WRITE source=USER_EDIT
graph_id_tag_update: id=SCScene flags=TRANSFORM, GEOMETRY, COPY_ON_WRITE source=USER_EDIT
DEG_relations_tag_update: Tagging relations for update.
ED_screen_refresh: set screen
After 20 minutes…
time bl_operators 0.0243
time bl_ui 0.0779
time keyingsets_builtins 0.0015
time nodeitems_builtins 0.0050
bl_app_template_utils.reset('')
addon_utils.enable io_anim_bvh
addon_utils.enable io_curve_svg
addon_utils.enable io_mesh_ply
addon_utils.enable io_mesh_stl
addon_utils.enable io_mesh_uv_layout
addon_utils.enable io_scene_fbx
addon_utils.enable io_scene_gltf2
addon_utils.enable io_scene_obj
addon_utils.enable io_scene_x3d
addon_utils.enable cycles
addon_utils.enable pose_library
addon_utils.enable node_arrange
addon_utils.enable node_wrangler
Python Script Load Time 0.2744
Warning, unregistered class: ViewLayerAOVPanel(Panel)
Warning, unregistered class: ViewLayerCryptomattePanel(Panel)
Warning, unregistered class: CyclesPresetPanel(Panel)
[SCScene :: ViewLayer]: Removed 24 relations to no-op nodes
graph_id_tag_update: id=SCScene flags=TRANSFORM, GEOMETRY, SHADING, SELECT, BASE_FLAGS, POINT_CACHE, COPY_ON_WRITE, SEQUENCER_STRIPS, AUDIO_SEEK, AUDIO_FPS, AUDIO_VOLUME, AUDIO_MUTE, AUDIO_LISTENER, AUDIO, PARAMETERS, TAG_FOR_UNDO source=RELATIONS
graph_id_tag_update: id=OBCube flags=TRANSFORM, GEOMETRY, COPY_ON_WRITE source=RELATIONS
graph_id_tag_update: id=MECube flags=LEGACY_0 source=RELATIONS
graph_id_tag_update: id=MECube flags=COPY_ON_WRITE source=RELATIONS
graph_id_tag_update: id=MAMaterial flags=COPY_ON_WRITE source=RELATIONS
graph_id_tag_update: id=NTShader Nodetree flags=COPY_ON_WRITE source=RELATIONS
graph_id_tag_update: id=OBLight flags=TRANSFORM, GEOMETRY, COPY_ON_WRITE source=RELATIONS
graph_id_tag_update: id=LALight flags=COPY_ON_WRITE source=RELATIONS
graph_id_tag_update: id=OBCamera flags=TRANSFORM, GEOMETRY, COPY_ON_WRITE source=RELATIONS
graph_id_tag_update: id=CACamera flags=COPY_ON_WRITE source=RELATIONS
graph_id_tag_update: id=GRScene Collection flags=TRANSFORM, GEOMETRY, COPY_ON_WRITE source=RELATIONS
graph_id_tag_update: id=GRCollection flags=COPY_ON_WRITE source=RELATIONS
graph_id_tag_update: id=WOWorld flags=COPY_ON_WRITE source=RELATIONS
graph_id_tag_update: id=LSLineStyle flags=COPY_ON_WRITE source=RELATIONS
Depsgraph built in 0.012480 seconds.
graph_id_tag_update: id=SCScene flags=COPY_ON_WRITE source=VISIBILITY
graph_id_tag_update: id=OBCube flags=TRANSFORM, GEOMETRY, COPY_ON_WRITE source=VISIBILITY
graph_id_tag_update: id=MECube flags=LEGACY_0 source=VISIBILITY
graph_id_tag_update: id=MECube flags=COPY_ON_WRITE source=VISIBILITY
graph_id_tag_update: id=MAMaterial flags=COPY_ON_WRITE source=VISIBILITY
graph_id_tag_update: id=NTShader Nodetree flags=COPY_ON_WRITE source=VISIBILITY
graph_id_tag_update: id=OBLight flags=TRANSFORM, GEOMETRY, COPY_ON_WRITE source=VISIBILITY
graph_id_tag_update: id=LALight flags=COPY_ON_WRITE source=VISIBILITY
graph_id_tag_update: id=OBCamera flags=TRANSFORM, GEOMETRY, COPY_ON_WRITE source=VISIBILITY
graph_id_tag_update: id=CACamera flags=COPY_ON_WRITE source=VISIBILITY
graph_id_tag_update: id=GRScene Collection flags=COPY_ON_WRITE source=VISIBILITY
graph_id_tag_update: id=GRCollection flags=COPY_ON_WRITE source=VISIBILITY
graph_id_tag_update: id=WOWorld flags=COPY_ON_WRITE source=VISIBILITY
graph_id_tag_update: id=LSLineStyle flags=COPY_ON_WRITE source=VISIBILITY
[SCScene :: ViewLayer]: Operation is entry point for update: COPY_ON_WRITE()
[SCScene :: ViewLayer]: Operation is entry point for update: AUDIO_VOLUME()
[SCScene :: ViewLayer]: Operation is entry point for update: TRANSFORM_LOCAL()
[SCScene :: ViewLayer]: Operation is entry point for update: TRANSFORM_INIT()
[SCScene :: ViewLayer]: Operation is entry point for update: TRANSFORM_EVAL()
[SCScene :: ViewLayer]: Operation is entry point for update: PARAMETERS_EVAL()
[SCScene :: ViewLayer]: Operation is entry point for update: SCENE_EVAL()
[SCScene :: ViewLayer]: Operation is entry point for update: TRANSFORM_FINAL()
[SCScene :: ViewLayer]: Operation is entry point for update: PARAMETERS_EXIT()
[SCScene :: ViewLayer]: Operation is entry point for update: TRANSFORM_SIMULATION_INIT()
[SCScene :: ViewLayer]: Operation is entry point for update: GEOMETRY_EVAL()
[SCScene :: ViewLayer]: Operation is entry point for update: VIEW_LAYER_EVAL()
[SCScene :: ViewLayer]: Operation is entry point for update: GEOMETRY_SELECT_UPDATE()
[SCScene :: ViewLayer]: Operation is entry point for update: GEOMETRY_EVAL_INIT()
[SCScene :: ViewLayer]: Operation is entry point for update: PARAMETERS_ENTRY()
[SCScene :: ViewLayer]: Operation is entry point for update: OPERATION()
[SCScene :: ViewLayer]: Operation is entry point for update: GEOMETRY_EVAL_DONE()
[SCScene :: ViewLayer]: Operation is entry point for update: SEQUENCES_EVAL()
[SCScene :: ViewLayer]: Operation is entry point for update: AUDIO_ENTRY()
[SCScene :: ViewLayer]: Operation is entry point for update: SOUND_EVAL()
[SCScene :: ViewLayer]: Accumulated recalc bits for SCScene: 4286574467
[SCScene :: ViewLayer]: Accumulated recalc bits for OBCube: 8323
[SCScene :: ViewLayer]: Accumulated recalc bits for MECube: 4286574467
[SCScene :: ViewLayer]: Accumulated recalc bits for MAMaterial: 8320
[SCScene :: ViewLayer]: Accumulated recalc bits for NTShader Nodetree: 8320
[SCScene :: ViewLayer]: Accumulated recalc bits for OBLight: 8195
[SCScene :: ViewLayer]: Accumulated recalc bits for LALight: 8320
[SCScene :: ViewLayer]: Accumulated recalc bits for OBCamera: 8195
[SCScene :: ViewLayer]: Accumulated recalc bits for CACamera: 8192
[SCScene :: ViewLayer]: Accumulated recalc bits for GRScene Collection: 8195
[SCScene :: ViewLayer]: Accumulated recalc bits for GRCollection: 8192
[SCScene :: ViewLayer]: Accumulated recalc bits for WOWorld: 8320
[SCScene :: ViewLayer]: Accumulated recalc bits for LSLineStyle: 8192
[SCScene :: ViewLayer]: deg_evaluate_copy_on_write on LSLineStyle (00000130842B7DB8)
[SCScene :: ViewLayer]: deg_evaluate_copy_on_write on NTShader Nodetree (000001308431C438)
[SCScene :: ViewLayer]: deg_evaluate_copy_on_write on SCScene (0000013084346078)
[SCScene :: ViewLayer]: deg_evaluate_copy_on_write on WOWorld (00000130842BC438)
[SCScene :: ViewLayer]: deg_evaluate_copy_on_write on GRCollection (00000130842BD338)
[SCScene :: ViewLayer]: deg_evaluate_copy_on_write on NTShader Nodetree (000001308431D5B8)
[SCScene :: ViewLayer]: deg_evaluate_copy_on_write on LALight (00000130FF975E38)
[SCScene :: ViewLayer]: deg_evaluate_copy_on_write on OBLight (0000013084350138)
[SCScene :: ViewLayer]: deg_evaluate_copy_on_write on CACamera (000001308431D338)
[SCScene :: ViewLayer]: deg_evaluate_copy_on_write on GRScene Collection (00000130842BE238)
[SCScene :: ViewLayer]: deg_evaluate_copy_on_write on MAMaterial (00000130842EDB78)
[SCScene :: ViewLayer]: deg_evaluate_copy_on_write on MECube (000001308433C138)
[SCScene :: ViewLayer]: deg_evaluate_copy_on_write on OBCamera (0000013084350838)
[SCScene :: ViewLayer]: deg_evaluate_copy_on_write on OBCube (000001308438CF38)
[SCScene :: ViewLayer]: layer_eval_view_layer on ViewLayer (00000130842AAFB8)
[SCScene :: ViewLayer]: BKE_object_eval_local_transform on OBCube (000001308438CF38)
[SCScene :: ViewLayer]: BKE_mesh_eval_geometry on MECube (000001308433C138)
[SCScene :: ViewLayer]: BKE_material_eval on MAMaterial (00000130842EDB78)
[SCScene :: ViewLayer]: BKE_object_data_select_update on MECube (000001308433C138)
[SCScene :: ViewLayer]: BKE_light_eval on LALight (00000130FF975E38)
[SCScene :: ViewLayer]: BKE_object_eval_local_transform on OBCamera (0000013084350838)
[SCScene :: ViewLayer]: BKE_world_eval on WOWorld (00000130842BC438)
[SCScene :: ViewLayer]: BKE_object_eval_local_transform on OBLight (0000013084350138)
[SCScene :: ViewLayer]: SEQ_eval_sequences on SCScene (0000013084346078)
[SCScene :: ViewLayer]: BKE_object_eval_eval_base_flags on OBCamera (0000013084350838)
[SCScene :: ViewLayer]: BKE_object_eval_eval_base_flags on OBCube (000001308438CF38)
[SCScene :: ViewLayer]: BKE_object_eval_eval_base_flags on OBLight (0000013084350138)
[SCScene :: ViewLayer]: BKE_object_eval_transform_final on OBCube (000001308438CF38)
[SCScene :: ViewLayer]: BKE_object_eval_uber_data on OBCube (000001308438CF38)
[SCScene :: ViewLayer]: BKE_object_handle_data_update on OBCube (000001308438CF38)
[SCScene :: ViewLayer]: BKE_object_eval_transform_final on OBLight (0000013084350138)
[SCScene :: ViewLayer]: BKE_object_eval_transform_final on OBCamera (0000013084350838)
[SCScene :: ViewLayer]: BKE_object_select_update on OBCube (000001308438CF38)
[SCScene :: ViewLayer]: BKE_object_data_select_update on MECube (0000013083CB6B38)
Depsgraph updated in 0.018942 seconds.
Depsgraph evaluation FPS: -nan(ind)
loading preset: C:\Program Files\Blender Foundation\Blender 3.0\3.0\scripts\presets\keyconfig\Blender.py
FRS_set_context: context 0x0000013081B61EF8 scene 0x00000130840C00B8
UI_menutype_draw: opening menu "WM_MT_splash"
ghost_event_proc: ghost redraw 1
wm_event_do_handlers: Handling event
wmEvent type:260 / WINDOW_DEACTIVATE, val:0 / NOTHING,
prev_type:0 / NONE, prev_val:0 / NOTHING,
shift:0, ctrl:0, alt:0, oskey:0, keymodifier:0, is_repeat:0,
mouse:(36682,-31003), ascii:'', utf8:'', pointer:000001308437EA78
UI_menutype_draw: opening menu "TOPBAR_MT_editor_menus"
UI_menutype_draw: opening menu "TIME_MT_editor_menus"
UI_menutype_draw: opening menu "VIEW3D_MT_editor_menus"
mouse:(2276,22), ascii:'', utf8:'', pointer:0000013093D53978
