Very early WIP for these changes:
I think that this is a good idea. Starting a new template (based on the curve one), and then little improvements in order to get it more sound oriented…
@pistolario As you originally had several EQ modifiers stacked, I guess, if users divide the full range into 3 modifiers each covering 1/3 of the range, that shouldn’t break the output sound, right?
Currently, with the sound EQ there are 2 modes of work:
- one modifier with a lot of curves. Values are replaced in the range that the curve cover with a little of “softenen” in the edges. The n curves can be created by python script
- n modifiers. Each modifier is a full range EQ. So they stack the results
So, the capture you link is possible NOW
