I want to understand behind the design of sync in UV tools.
The way it design make it confuse, between sync and unsync
to explain it
when toggle sync it should be in “Select UV mode” and not to change to “Select Mode”
Please tell me if there is a reason when you sync it goes to select mode ?
I hope if there is a way to do it or as an option
This gonna short it less click and less confuse.
Thanks
