Hi!
I’m trying to understand the tool/gizmo code by making a transform tool for sculpt mode.
As a starting point, I would like to reuse the same transform gizmo and operator keymap from the regular transform tool. Let’s say I have a mat4 in SculptSession
representing the pivot point of the transform. Is there a way to transform that matrix using the same functions defined in transform.h
(like transformEvent()
, transformApply()
Thank you.
Currently there isn’t a field that’s used for this.
You could start by decomposing the matrix and transforming a location, scale & quaternion (see TransDataExtension
and instances of TD_USEQUAT
this can be converted back into a matrix after transforming.
