It seems aoMap is not properly handled when you import .usd, not sure if this was a bug or a not implemented feature so I thought I’d ask the forum first. Please let me know if this is more suitable for feature requests or bug reports.
Unfortunately, I can’t share the asset but I could share USD code snippets of material nodes that works and that not.
So for example, the inputs:emissiveColor node in the following material in .usd is imported correctly by blender and it produces proper shader node in blender:
def Material "JPWuURAYZptTggM"
token outputs:surface.connect = </tracking_node_placeholder/Looks/JPWuURAYZptTggM/YEnKIwPtpiQtnCt.outputs:surface>
def Shader "YEnKIwPtpiQtnCt"
uniform token info:id = "UsdPreviewSurface"
color3f inputs:diffuseColor = (0, 0, 0)
color3f inputs:emissiveColor.connect = </tracking_node_placeholder/Looks/JPWuURAYZptTggM/vFQNheUtEsyRLKf.outputs:rgb>
float inputs:metallic = 0.85
float inputs:roughness = 0.2
token outputs:displacement
def Shader "vFQNheUtEsyRLKf"
uniform token info:id = "UsdUVTexture"
float4 inputs:fallback = (0.5, 0.5, 0.5, 1)
asset inputs:file = @./0/GyYmtUyAzPVgajS.png@
float2 inputs:st.connect = </tracking_node_placeholder/Looks/JPWuURAYZptTggM/vFQNheUtEsyRLKf/TexCoordReader.outputs:result>
float3 outputs:rgb
def Shader "TexCoordReader"
uniform token info:id = "UsdPrimvarReader_float2"
token inputs:varname = "st"
float2 outputs:result
Whereas, the following material has inputs:occlusion node and it isn’t imported by blender thus blender doesn’t produce aoMap node in shader:
def Material "fAgLLeyEMIIowve"
token outputs:surface.connect = </tracking_node_placeholder/Looks/fAgLLeyEMIIowve/mPAEhjajDvmMqEu.outputs:surface>
def Shader "mPAEhjajDvmMqEu"
float inputs:occlusion.connect = </tracking_node_placeholder/Looks/fAgLLeyEMIIowve/VNPlQxWkTOPrPMR.outputs:r>
float inputs:roughness = 1
def Shader "VNPlQxWkTOPrPMR"
asset inputs:file = @./0/bGnxnqSJyxiZfPi.png@
float2 inputs:st.connect = </tracking_node_placeholder/Looks/fAgLLeyEMIIowve/VNPlQxWkTOPrPMR/TexCoordReader.outputs:result>
float outputs:r
float3 outputs:rgb
(Attached the screenshot in the comment, it seems I can embed only one media since I’m a new member. There are only Principled BSDF and Material Output in the shader node)
I’m working with blender 3.0.1 on intel mac, importing .usd with the bundle .usd import module.
Is this expected? Or should be reported as a bug?
If this is expected, is there any way to get around it to make the aoMap work? Any pointer would be appreciated. Thanks for reading.
Thanks again for your answers!
