Unable to MAKE [SOLVED]
I don’t know if is a my problem or a Blender problem. Thank you
System Information
Operating system: Linux-6.7.0-arch3-1-x86_64-with-glibc2.38 64 Bits, X11 UI
Graphics card: Mesa Intel(R) HD Graphics 5500 (BDW GT2) Intel 4.6 (Core Profile) Mesa 23.3.4-arch1.2
Blender Version
Broken: version: 4.1.0 Alpha, branch: main, commit date: 2024-01-30 04:56, hash: 948e806a1a43
Worked: (newest version of Blender that worked as expected)
the version of 2 days ago
Short description of error
[Please fill out a short description of the error here]
Exact steps for others to reproduce the error
make[3]: *** [source/blender/compositor/CMakeFiles/bf_compositor.dir/build.make:233: source/blender/compositor/CMakeFiles/bf_compositor.dir/Unity/unity_15_cxx.cxx.o] Error 1
make[3]: *** Attesa per i processi non terminati…
make[3]: *** [source/blender/compositor/CMakeFiles/bf_compositor.dir/build.make:89: source/blender/compositor/CMakeFiles/bf_compositor.dir/Unity/unity_24_cxx.cxx.o] Error 1
make[3]: *** [source/blender/compositor/CMakeFiles/bf_compositor.dir/build.make:217: source/blender/compositor/CMakeFiles/bf_compositor.dir/Unity/unity_16_cxx.cxx.o] Error 1
make[3]: *** [source/blender/compositor/CMakeFiles/bf_compositor.dir/build.make:201: source/blender/compositor/CMakeFiles/bf_compositor.dir/Unity/unity_17_cxx.cxx.o] Error 1
make[2]: *** [CMakeFiles/Makefile2:8006: source/blender/compositor/CMakeFiles/bf_compositor.dir/all] Error 2
make[1]: *** [Makefile:166: all] Error 2
make: *** [GNUmakefile:387: all] Error 2
Did you do all the steps described here: Building Blender - Blender Developer Documentation
certainly, like every day.
make update
make
using main branch on linux
Thank you very much for your interest.
Looks like the same issue as:
Might be a temporary issue that resolves when you update again.
If not, would be good to see the full build log.
Sorry, where i find the full build log?
In my shell I typed
$ make full > make_full.txt 2>&1
Then I uploaded make_full.txt in my message.
Thank you very much, you are very kind, it works now but I will save the message for the future. now it compiles without errors, but I have rendering problems which I’m going to report in the other forum after having done a bit of testing.
A thousand thanks.
What did you do to get it to compile?
I currently have similar compilation errors when trying to compile on Linux Mint today.
make[3]: *** No rule to make target 'source/blender/compositor/CMakeFiles/bf_compositor.dir/cmake_pch.hxx.gch', needed by 'source/blender/compositor/CMakeFiles/bf_compositor.dir/Unity/unity_24_cxx.cxx.o'.  Stop.
make[2]: *** [CMakeFiles/Makefile2:8137: source/blender/compositor/CMakeFiles/bf_compositor.dir/all] Error 2
After an update of Arch (kernell and GCC) it works. i do nothing.
(I update Arch and blender very often, and maybe sometimes blender precedes Arch in changing some files, or maybe temporary problems when changing many things, I don’t know, I report any errors I find in the hope of helping)
Thanks for the reply. I updated cmake to 3.28.2 yesterday, and in the MacOS thread mentioned a few posts above it looks like this is the cause.
What cmake version are you using?
cmake version 3.28.2
CMake suite maintained and supported by Kitware (kitware.com/cmake).
Dang… that’s my version too. So that might not be the cause.
The last Arch update:
binutils-2.42-1 curl-8.6.0-1 fakeroot-1.33-2 gcc-13.2.1-4 gcc-libs-13.2.1-4 glibc-2.38-8
libnghttp2-1.59.0-2 libpng-1.6.42-1 linux-6.7.2.arch1-2 opera-106.0.4998.70-1 sqlite-3.45.1-1
Thanks again. I downgraded to cmake 3.27.9 and all is shiny again.
I didn’t know that cmake can be too new, in the past I only had problems with cmake being too old :sweat_smile:
Ah, there we have it:
P.S.: It’s about 3.28.2 obviously, not 2.28.2
I’ve had the exact same error as in February 2024 for three days. After an update, both for Arch and Blender, Blender no longer works. Since the problem resolved itself last time, I’m confident it will be the same this time too. Just wait, but I think it’s right to notify the forum that the problem exists.
cmake version 4.1.1
make_full.txt (369.5 KB)
I’ll keep updating…
That one is the same as Missing libtiff symbols when building on Arch Linux - #6 by LazyDodo
We don’t really understand why it (re)appeared on Arch based distros recently, but the upcoming lib updates for 5.0 are supposed to fix this.
