Trying to Build Blender but getting Cmakr Error
System Information
Operating system: Ubuntu 19.04
Cmake Version: 3.13.4
Blender Version
Broken: Honestly have no idea.
Using visual studio latest version.
followed the build blender wiki using pre-compiled libs.
** Error **
Configuring Blender in "/home/ashwin/Documents/GSOC/Blender/build_linux" ...
-- Using pre-compiled LIBDIR: /home/ashwin/Documents/GSOC/Blender/blender/../lib/linux_centos7_x86_64
-- Could NOT find Jack (missing: JACK_LIBRARY JACK_INCLUDE_DIR)
CMake Warning at /usr/share/cmake-3.13/Modules/FindBoost.cmake:880 (message):
  New Boost version may have incorrect or missing dependencies and imported
  targets
Call Stack (most recent call first):
  /usr/share/cmake-3.13/Modules/FindBoost.cmake:1002 (_Boost_COMPONENT_DEPENDENCIES)
  /usr/share/cmake-3.13/Modules/FindBoost.cmake:1670 (_Boost_MISSING_DEPENDENCIES)
  build_files/cmake/platform/platform_unix.cmake:324 (find_package)
  CMakeLists.txt:801 (include)
-- Boost version: 1.70.0
-- Found the following Boost libraries:
--   filesystem
--   regex
--   thread
--   date_time
--   wave
--   locale
--   iostreams
--   system
--   chrono
--   atomic
--   serialization
runningllvm-config-
CMake Error at build_files/cmake/platform/platform_unix.cmake:417 (if):
  if given arguments:
    "WITH_OPENCOLLADA" "AND" "(" "VERSION_LESS" "4.0.0" ")"
  Unknown arguments specified
-- Configuring incomplete, errors occurred!
See also "/home/ashwin/Documents/GSOC/Blender/build_linux/CMakeFiles/CMakeOutput.log".
See also "/home/ashwin/Documents/GSOC/Blender/build_linux/CMakeFiles/CMakeError.log".
make: *** [GNUmakefile:312: all] Error 1
try if(WITH_OPENCOLLADA AND ("${LLVM_VERSION}" VERSION_LESS "4.0.0")) at build_files/cmake/platform/platform_unix.cmake:417
instead of if(WITH_OPENCOLLADA AND (${LLVM_VERSION} VERSION_LESS "4.0.0"))
for silencing those warnings, one can turn OFF boost, if not required wiki.blender.org/wiki/Building_Blender/Options#Editing_CMake_Options
@ankitm
This worked but then I encountered a new error after that while linking cxx executable. the error is too big to post here but what I understood by it is cmake isn’t recognising any function or variables in script being executed, Its showing lots of error:undefined reference to …
Please help
Paste on https://hastebin.com
https://hastebin.com/olevipateg.rb
almost every library is giving errors… Why don’t you try Cmake’s latest version ?Download CMake
Even after updating cmake it’s giving the same error :zipper_mouth_face:
Precompiled libraries for Linux, aren’t yet very stable. It requires some manual patching to the patch itself. You may have better luck when combining running make deps and install_deps.sh. The install_deps.sh adds the missing libraries to opt/libs, but some may fail like ilmbase (download longer exists), if that happens, you can use make deps, and copy some of those libraries to opt/libs.
Hi, I run into the same problems with the prebuild libraries but got it to build with some tweaking.
Here is the tread with some steps we try: Linking errors with prebuild libs on Linux
There is a patch in the works but not finished atm. https://developer.blender.org/D6888
I had a working build system with mixed libraries from make deps script, system and self build libs but is really a mess and not comparable to the release builds or build bot builds.
CHeers, mib
Since I was unable to build blender on ubuntu I built it on windows :slight_smile:
Hi, when do you try on Linux?
It is all fixed now in master with the prebuild libraries, delete the the build_linux directory to make sure all is clean.
Cheers, mib
