Its a lot of unnecessary mouse movement and button presses to swap the naviation function between zoom, rotate and pan. Example of moving around a single point in space -
rotate - zoom - rotate - zoom (zoom to mouse position and depth are enabled in preferences)
rotate
place mouse over point to rotate around
press middle mouse
move mouse away from that point to rotate
zoom
let go of middle mouse
move pointer back to original position
press ctrl
press middle mouse
move mouse away from that point to zoom in
rotate again
let go of ctrl
move mouse back to original position
press middle mouse
move mouse away from this position to rotate
zoom again
move mouse back to same position yet again
press ctrl
press middle mouse
move mouse forwards
SOLUTION
That’s a lot of unnecessary button presses, releases and extra mouse movement. The solution is to be able to change the command without having to let go of the middle mouse. This would also mean you wouuldn’t have to move the mouse back to the original point, because Blender would continue using the point originally set.
The above rotate - zoom - rotate - zoom would become:
place pointer over position
press middle mouse
move mouse around
press ctrl
move mouse to zoom around original point
let go of ctrl
move to rotate
press crtrl
move to zoom
That’s removing 50% of your viewport navigation button presses and arm movement!
Heya, just wanted to share my experience using the viewport navigation.
I remapped the buttons a bit, Holding Right mouse rotates viewport, middle mouse is pan and scroll is zoom, i still retain the ability to call the context menu window with a right click.
Interesting, but you still have a lot more steps than my suggestion above, plus you still need to move the mouse back to the original point each time you change between zoom, rotate and pan.
Select object or in edit mode select face/edge/vert
View selected ( i dont use zoom to pointer cause its more work that it is helpful)
then rotate or pan or zoom,
To me its irrelevant where the mouse pointer is as long as its in the viewport.
I suppose for your case it would be practical if the mouse did not move through the viewport as you drag it while pan/rotate/zoom is activated, that would at least spare you the moving the mouse pointer back and forth to the same position
You don’t have to use Ctrl to zoom, that’s only useful for precision zooming. You can simply just roll your wheel. Also you don’t have to pan that much if you’ve got Zoom to mouse position enabled (which I highly recommend).
Don’t think this needs any changing in Blender. It’s very possible your solution would fail badly in real world scenarios when it comes to multiple various workflows people have.
